BT.com
Wishlist
Asus TUF X299 MARK 1 Intel X299 S2066 DDR4 M.2 USB3.1 ATX
Asus TUF X299 MARK 1 Intel X299...
£278.35
Hurry, only 1 left in stock!
£278.35
Add to wishlist
Delivery
Standard 1-3 working days
ASUS TUF X299 MARK 1 - motherboard - ATX - LGA2066 Socket - X299
Motherboard - ATX
Chipset Type
Intel X299 Express
Processor Socket
1 x LGA2066 Socket
Compatible Processors
Core X
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 4 x USB 2.0 + (1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel X299 Express
Processor Socket
LGA2066 Socket
Max Processors Qty
1
Core X
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 3600 MHz (O.C.), 4000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Audio
Audio Codec
Realtek ALCS1220A
DTS Connect, High Definition Audio, DTS Headphone:X
LAN
Network Controller
Intel I219V / I211
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 (44-lane CPU (x16, x16/x16, x16/x16/x8 modes), 28-lane CPU (x16, x16/x8, x16/x8/x4 modes), 16-lane CPU (x16, x8/x8, x8/x8/x1 modes)) , 2 x PCIe 3.0 x4
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
RAID Features
Intel Smart Response Technology
2 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 4 x USB 2.0 , 1 x TOSLINK , 1 x USB 3.1 Gen 2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x USB-C Gen2
Internal Interfaces
2 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x Thunderbolt - header , 1 x USB 3.1 Gen 2 - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, USB BIOS Flashback, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, MemOK!, ASUS Q-Design, TUF Engine!, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, TUF Thermal Armor, Intel Smart Response Technology, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, Ultimate COOL!, Safe & Stable! Guardian Angel, TUF Dust Defender, TUF Fortifier, Preboot eXecution Environment (PXE), anti-pop function, Turbo LAN, TUF ICe, TUF ESD Guards 2, TUF LANGuard, ASUS PRO Clock Technology, TUF Detective 2, TUF Components, AURA RGB Lighting Control, ASUS SafeSlot, Intel Turbo Boost Technology 3.0, Intel Optane Memory Ready, TUF Thermal Radar 3
I/O back plate, 1 x M.2 screw, dust covers, TUF stickers, vertical M.2 bracket set, TUF dongle, TUF VGA holder
4 x Serial ATA cable , 1 x 3-way SLI bridge , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version)
30.5 cm
24.4 cm
Scroll to top
