BT.com
Wishlist
Asus Sabertooth Z77 S1155 Intel Z77 DDR3 ATX
Delivery
Standard Due date unavailable
SABERTOOTH Z77: The ultimate thermal solution for Intel® Z77 motherboards with Thermal Armor and Thermal Radar
  • LGA1155 Intel® 3rd/2nd Generation Processors Ready
  • TUF Thermal Armor - Total Airflow-Boosting Heat Dissipation
  • TUF Dust Defender - Repel the Dust, Expand the Lifespan
  • TUF Thermal Radar - Real Time Temp. Detection and Heat Removal
  • TUF Components [Choke, Cap. & MOSFET; Certified by Military-standard] - Certified for Tough Duty
  • New DIGI+ Power Control - All-New Digital Power Control for both CPU and DRAM
TUF /t?f/, stands for The Ultimate Force.
The TUF series delivers a "tough" image. With the unique design & high quality components (military-standard), TUF series is born for pursuing the preeminent stability, all-round compatibility, and extreme durability
"Ultimate COOL!" Thermal Solution: Thermal Armor, Total Airflow-Boosting Heat Dissipation
New generation Thermal Armor boosts cooling with dual turbo fans, enhancing the original TUF thermal design and helping direct hot air away from components and the motherboard via smart shunt funneling. It covers the entire board with more powerful airflow, and uses special heat pipes to expedite thermal removal and make sure temperatures stay low. The dedicated I/O cover fan draws additional cold air in and expels even more heat for improved stability, plus new Thermal Armor comes with special convection holes in the PCB to facilitate underside airflow. It now sports a cool military-themed style, perfect for case modders.
Thermal Radar: Real Time Temp Detection and Heat Removal
Thermal Radar monitors temperatures in critical parts of the board, automatically adjusting fan speeds for better system stability. Fan Overtime keeps fans working in critical minutes post shutdown to extend component lifespan, dropping temperatures by 7?C in just ten minutes after the computer turns off. New Fan Off consists of a switch that disables fans should temperatures drop below a manually or automatically set level for effective power consumption.
"Safe & Stable!" Guardian Angel: Dust Defender, Repel the Dust, Expand the Lifespan
Dust particles and environmental contamination present a constant hazard to the optimal functioning of slots and connectors. Build up on contact points within slots compromises data transfer over time, negating the benefits of expensive and critical components such as graphics cards. Custom TUF design keeps this in mind with special shields that resist particulate entry, effectively extending slot and connector lifespan while promoting better performance.
ESD Guards: Unique protection of motherboard components from unexpected electrostatic discharges (ESD)
Electrostatic discharge (ESD) can happen suddenly and its damaging effects is often underestimated. Exclusive ASUS anti-static chip, a protective circuit design, and the I/O shield provides four times better protection to extend component lifespan.
This motherboard supports Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world
Intel® Z77 Express Chipset
The Intel® Z77 Express Chipset is a single-chipset design to support socket 1155 Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z77 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel® Z77 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
PCIe 3.0 Ready
PCI Express® 3.0 (PCIe 3.0) is the latest PCI Express bus standard with improved encoding schemes that provide twice the performance of current PCIe 2.0. Total bandwidth for a x16 link reaches a maximum of 32GB/s, double the 16GB/s of PCIe 2.0 (in x16 mode). As such, PCIe 3.0 provides users unprecedented data speeds, combined with the convenience and seamless transition offered by complete backward compatibility with PCIe 1.0 and PCIe 2.0 devices. PCIe 3.0 will become a must-have feature for users who wish to improve and optimize graphic performance, as well as have the latest technology available to them. * PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
Quad-GPU SLI and Quad-GPU CrossFireX Support! Flexible Multi-GPU Solutions, Your Weapon of Choice!
SABERTOOTH Z77 brings you the multi-GPU choice of either SLI™ or CrossFireX. The motherboard features the most powerful Intel® Z77 platform to optimize PCIe allocation in multiple GPU configurations. Expect a brand-new gaming style you've never experienced before!
ASUS SABERTOOTH Z77 - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600, 4 x SATA-300 (RAID), 2 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
Max Allocated RAM Size
1696 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
5 years warranty
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz
Speed
PC3-12800, PC3-10600, PC3-14900
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1696 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Intel 82579V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin SATA, 2 x 7pin eSATA - 4 devices
RAID Features
Intel Smart Response Technology
1 x HDMI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x USB 3.0 - header , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, TUF Engine!, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, TUF Thermal Armor, TUF Thermal Radar, Intel Clear Video HD Technology, Intel Smart Response Technology, USB 3.0 Boost, AMD Quad CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Network iControl, ASUS USB Charger+, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, 8+4+2 Phase Power Design, Ultimate COOL!, Safe & Stable! Guardian Angel, TUF Dust Defender
2 x 35mm fans, accessory package
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Limited warranty - 5 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Asus Sabertooth Z77 S1155
Reviewed by Bob M on 11/08/2012
Upgraded from my original striker extreme. This board is just simply amazing. Now running with 460 GTX in SLI, Intell I5 5550 and 16 Gig of Corsair Ram. Can I just say my jaw dropped and hit the floor when I loaded up Battlefield 3 One of the easiest boards to install and like me is looks sooooooooooo cool. Well done. Thanks BT for a great price, great delivery.
5* Fantastic Board
Reviewed by Jamie Haden on 03/01/2013
This board is a dream; the only fiddly part is mounting the board to the case as the thermal armour means u need a long screwdriver to fix the board.
The monitoring software is a dream as well as the UEFI bios; its extremely easy to configure and there are failsafes should you go wrong. A huge factor is the fact it will charge your smart phone as if it was plugged into the mains; you must choose the correct USB3 port on the back though
Scroll to top
