Asus SABERTOOTH P67 REV 3.0 LGA1155 Intel P67 DDR3 ATX (B3 Stepping)
Standard Due date unavailable
Sabertooth TUF P67 Series Motherboard
REV 3.0 - New P67 B3 Revision
Intel P67 Based Military-grade Motherboard with Thermal Armor
  • Intel® LGA1155 socket for Intel® 2nd Generation Core™ i7/ Core™ i5/ Core™ i3 Processors
  • Intel® P67 Express Chipset
  • TUF Thermal Armor - Total Airflow-Boosting Heat Dissipation
  • TUF Thermal Radar - Real Time Temp Detection and Heat Removal
  • TUF Components [Alloy Choke, Cap. & MOSFET; Certified by Military-standard] - Certified for Tough Duty
  • E.S.P. [Efficient Switching Power Design] - Optimal power efficiency for key components
Unlike ordinary motherboards, ASUS TUF series motherboards are tested under extreme environmental conductions, above the already industry leading reliability test of ASUS. This is beyond the reach of standard motherboards, ensuring real toughness is achieved throughout the whole board rather than only components, setting a new standard for the motherboard industry. All TUF series motherboards must pass the ultra-critical operation environment tests inside chassis under both the low chamber room temperature of -10 degrees, and the high temperature with high humidity environment of 55 degrees at 90% humidity. This ensures stable operation can be achieved in any part of the world under the worst possible conditions.
8+2 Phase DIGI+ VRM (Digital VRM)
Unlike ordinary digital VRM designs, DIGI+ VRM combines the advantage of both the digital and analogue VRM design, delivering less switching delay while offering better accuracy at the same time. Delivering better permeability and less power loss, meaning less heat will be produced compared with the traditional digital VRM design. Furthermore, control options are available within both the BIOS and windows, allowing the users complete control.
TUF Components: TUF series motherboards consist of three key components
TUF Capacitor: Industry top graded Japanese capacitors approved by ISO and IEC/IECQ certified independent
Laboratories meet military standard. 2.5X more durable than ordinary Japan branded conductive polymer aluminium solid capacitors (also known as Solid Cap), and 1.67X more durable than the even the top graded polymer tantalum capacitor (also known as Hi-C Cap) under the same environment temperature.
TUF MOSFET: Industry top graded low RDS(On) MOSFET, approved by ISO and IEC/IECQ certified independent
Laboratories meet military standard. These MOSFETs deliver robust efficiency whilst also sustaining the ultra-critical thermal shock of between -65~150°C. The power solution is formed by four of this type of MOSFETs, delivering unbeatable performance as well as durability.
TUF Chokes: Industry top standard approved by ISO and IEC/IECQ certified independent laboratory to meet military standard.
TUF Chokes, also known as the "Alloy Choke", is a made of a compound of various types of metal instead standard iron, enables the support of up to a massive 40A of rated current, 25% higher than conventional component. Furthermore, the single piece packaging also eliminates the emission of vibration noise, delivering superb characteristics as well as durability under extreme conditions.
Key Features
TUF Thermal Armour
The motherboard temperature is affected by both the heat generated by itself as well as its surrounding components, which often leads to potential stability risks and a shortened life of on-board components. The TUF Thermal Armour adopts the concepts of both "block" and "redirect" via the use of a specially designed air duct covering all critical parts of the motherboard, physically "blocking the hot air from the VGA card" and "redirects airflow towards the locations needing them", further improves the heat dissipation capability of the board under the same environment as is without.
TUF Thermal Radar
It is essential to keep the system temperature as low as possible for ultimate reliability and durability, it is in most cases impossible to do so effectively due to the limited number of temperature sensors available, which are only able to represent the temperature of one single location on the motherboard, the temperature of other parts is simply ignored, resulting in the potential risks of an unexpected system breakdown.
This is the concept behind the TUF Thermal Radar. With a total of up to 12 sets of thermal sensors around the most temperature critical locations surrounding the motherboard, this allows users to have a total picture of the thermal status of the entire board. The Thermal Armour, when used with only one single down draft CPU fan fitted on-board, can redirect the airflow towards the other heat critical parts with its unique shunt or baffle design. Furthermore, with the capability to allow the complete redefinition of the fan curve as well as being able to control the fan speed based on the selection of up to three different locations with the custom definition of the weighting of each of the three locations, making the fan control even more location specific, and more precise for the application of users.
ASUS Unique Selling Points
  • DIGI+ VRM - Digital Phase power control for ultimate power efficiency and overclocking.
  • TUF Thermal Armor - Superior cooling performance
  • TUF Thermal Radar - 12 hardware sensors embedded for real-time thermal detection
  • CeraM!X Heatsink Coating Technology, Larger area for heat dissipation with the revolutionary ceramics-coating technology
  • E.S.P. Efficient Switching Power Design, Optimal power efficiency for key components
  • TUF Components Alloy Choke, Cap. & MOSFET, certified by military-standard testing, Certified for totally stable performance
  • MemOK! determines failsafe settings and dramatically improves your system boot success with Memory.
Key specification
  • ATX Form Factor
  • LGA1155 socket for Intel® 2nd Generation Core™ i7/ Core™ i5/ Core™ i3 Processors
  • 4 x DDR3, up to 32.0G
  • 2 x PCI Express 2.0 x16 slots (single at x16 or dual at x8/x8 mode)
  • Supports NVIDIA® Quad-GPU SLI™ Technology
  • Supports ATI® Quad-GPU CrossFireX™ Technology
  • 8-CH HD audio
  • Gigabit LAN controller
  • Front Panel USB 3.0 Support
  • 2 x SATA 6Gb/s ports (brown)
  • 4 x SATA 3Gb/s ports (black)
  • 2 x SATA 6Gb/s ports (gray)
  • 1 x Power eSATA 3Gb/s port (green)
  • 1 x eSATA 3Gb/s port (red)
In The Box
  • 2 x Serial ATA 6Gb/s cables
  • 2 x Serial ATA 3Gb/s cables
  • 1 x ASUS SLI bridge cable
  • 1 x ASUS Q-Shield
  • 1 x 2 in 1 Q-connector
  • 1 x TUF Certification card
  • 1 x TUF 5 Year Warranty manual (by region)
  • 4 x screws for Assistant Fan
  • User's manual
ASUS SABERTOOTH P67 - 3.0 B3 - motherboard - ATX - LGA1155 Socket - P67
Motherboard - ATX
Chipset Type
Intel P67 Express
Processor Socket
1 x LGA1155 Socket
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600, 4 x SATA-300 (RAID), 1 x eSATA-300, 1 x powered eSATA-300
USB / FireWire Ports
2 x USB 3.0 + 1 x FireWire + 8 x USB 2.0 + ( 2 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel P67 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz
PC3-14400, PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture
Audio Codec
Realtek ALC882
High Definition Audio
Network Controller
Intel 82579
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , JMicron JMB362: SATA-300 -connectors: 1 x 7pin eSATA, 1 x 11pin eSATAp - 2 devices
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 1 x FireWire - 6 pin FireWire , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 8 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
2 x USB 3.0 , 1 x FireWire
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, ASUS EFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, MemOK!, 8+2 Phase Power Design, ESD Guards, TUF Engine!, Q-DIMM, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, TUF Thermal Armor, TUF Thermal Radar, ASUS DIGI+ VRM, AMD Quad CrossFireX technology support
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS Live Update, ASUS AI Suite II
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
