BT.com
Wishlist
Asus SABERTOOTH 990FX R3.0 AM3+ 990FX DDR3 M.2 USB3.1 ATX
Asus SABERTOOTH 990FX R3.0 AM3+...
£169.68
£169.68
Add to wishlist
Delivery
Standard Due date unavailable
The TUF series delivers a "tough" image. With the unique design & high quality components (military-standard), TUF series is born for pursuing the preeminent stability, all-round compatibility, and extreme durability.
ASUS TUF SABERTOOTH 990FX - 3.0 - motherboard - ATX - Socket AM3+ - AMD 990FX
Motherboard - ATX
Chipset Type
AMD 990FX / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Sempron X2, Phenom II X4, Phenom II X6, FX (supports CPUs with up to 8 cores, Maximum TDP 220 Watt)
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
Storage Ports
5 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C + 3 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I211
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 2.0 x16 (dual x16 mode; triple: x16, x8, x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1
Storage Interfaces
AMD SB950: SATA-600 -connectors: 5 x 7pin SATA - 5 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , AMD SB950: SATA-600 / PCIe -connectors: 1 x M.2 - 1 devices
1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 4 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x USB-C , 3 x USB 3.1
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
AMD Cool 'n' Quiet Technology, jack retasking, MemOK!, ASUS Q-Design, TUF Engine!, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, ASUS Precision Tweaker 2, NVIDIA 3-way SLI Technology Support, ASUS 8+2 Phase Power Design, NVIDIA Quad SLI Technology Support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Ultimate COOL!, Hyper Transport 3.0, TUF Thermal Radar 2, Preboot eXecution Environment (PXE), Turbo LAN, USB 3.1 Boost, TUF ESD Guards 2, TUF LANGuard, TUF Components, AURA RGB Lighting Control, ASUS SafeSlot
I/O back cover, TUF stickers
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS Update, ASUS AI Suite III, Antivirus (OEM version), Media Streamer
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
