BT.com
Wishlist
Asus RT-N65U Dual-Band Wireless-N750 Gigabit Router
Delivery
Standard Due date unavailable
2.4GHz and 5GHz concurrent dual-band transmissions with dual processor design for stronger signals and faster connection rates up to 750Mbps combined
Gigabit Ethernet ports with hardware NAT for the fastest, most reliable internet performance
Twin USB 3.0 ports provide SuperSpeed file, printer, and 3G sharing
Download Master for wireless data storage and access to router-connected USB storage devices
ASUSWRT dashboard UI offers easy setup, signal monitoring, and network application control
SuperSpeed USB 3.0 Data Sharing and Connections
The ASUS RT-N65U features the unique black diamond design and top performance of the award-winning RT-N56U, delivering exhilarating networking experiences. It comes equipped with a dual SoC architecture, one dedicated to 2.4GHz and the other to 5GHz, effectively offering the best concurrent throughput with up to a combined 750Mbps - great for high demand applications. Twin SuperSpeed USB 3.0 ports enhance file sharing and connectivity to devices, FTP, SAMBA, UPnP AV servers, and DLNA configurations. Equipped with powerful hardware NAT acceleration and built-in Gigabit Ethernet, the RT-N65U gives you full Gigabit internet performance, with its WAN and LAN throughput at over 900Mbps. In all, the RT-N65U's blend of design and performance guarantees truly great networking.
Whether you're a tech-savvy enthusiast or a first-time user, the RT-N65U is exceptionally easy to use with CD-free Quick Installation Setup (QIS) that lets you plug-n-surf right out of the box and connect PCs, smartphones, tablets, and other wireless devices quickly. Thanks to its refined interface tools, you get control like never before, letting you monitor signal strength, setup parental controls, and access various useful functions in the most intuitive way.
Dual Processor Design Maximizes Dual-Band Throughput
Dual processors feature one dedicated to 2.4GHz and another to 5GHz, offering the best concurrent throughput with dual-band 2.4GHz and 5GHz operation at up to a combined 750Mbps. The 2.4GHz band can handle basic tasks like web browsing, while 5GHz performs more bandwidth-intensive tasks like HD video streaming and online gaming.
SuperSpeed USB 3.0 Enhances Sharing
Featuring SuperSpeed USB 3.0 connectivity to devices, FTP, SAMBA, UPnP AV servers, and DLNA, the RT-N65U enhances data sharing and connections. Download HTTP, FTP, and P2P files to a router-connected USB storage device all day even without a PC. Additionally, the twin USB 3.0 ports allow networked printer and file server connections, so you can perform multiple tasks at once.
Optimized and Reliable Wireless Coverage via AiRadar
ASUS AiRadar intelligently strengthens connections to wireless devices. With high-powered amplification and beam packaging, it provides optimized signals in any direction with better coverage to improve your data throughput.
Gigabit Internet Browsing with Hardware NAT
Equipped with a powerful hardware NAT acceleration engine and built-in Gigabit Ethernet, the RT-N65U gives you full Gigabit performance, making its WAN to LAN throughput up to 2-5 times that of traditional software-based NAT Gigabit routers.
3-Step Easy Setup Through Your Pad, Smartphone, or PC
With the RT-N65U, setup is a breeze. Simply power and connect the router and open a browser on a Wi-Fi-enabled device like a notebook or pad. You will then be taken to a setup page with a prompt to enter the ID/password from your internet provider, and that's it! Setting up your network is easier than ever.
Get online in 30 seconds
Smart auto-detection design makes it possible for you to go from first plugging in the RT-N65U to setup completion in under 30 seconds! Compared to the lengthy installs and hassles of other routers, this development from ASUS offers a true wonder of ease of use, and puts the most extreme networking speeds within your reach quicker than ever before.
30 second setup
Powerful Online Multitasking at up to 300,000 Data Sessions
Support for a massive data pipeline of up to 300,000 data sessions means the RT-N65U has around 20 times the networking capacity of other high session routers, so multiple data transfer jobs don't slow down even during heavy load.
Download and Stream Anywhere
Download Master and DLNA server compatibility let you download and play multimedia files stored on router-attached USB storage on DLNA-enabled devices such as PC, pad, PS3, Xbox, and smart TV. Download Master can also download files while your PC is turned off, and allows you to manage and monitor download status remotely.
Optimize Your Network
Do you game a lot, or spend most of your time streaming videos? Whatever your planned use is, the RT-N65U has Quality of Service (QoS) standards that let you select how much bandwidth is prioritized for virtually any task. Plus, the traffic monitor allows you to check your web usage in a clear graphical interface.
Powerful Functions, Easiest Management
With the ASUSWRT Dashboard UI, setup, monitor, and control network applications all in one intuitive area. The new dashboard interface lets you manage all clients and settings on a single graphical interface with 1-click updates.
Discrete and Secure Wi-Fi Networks via Guest Access
The RT-N65U supports up to three wireless guest networks over the 2.4GHz band and three over the 5GHz band, so it can protect computers from unauthorized access, hacking, and virus attacks. Additionally, parental controls allow you to set up online access times and levels for kids.
VPN Server Enabled
Easily set up a VPN server to browse the web and access data -- no matter where you are. Featuring MPPE encryption, your data transmission remains always secure and confidential.
ASUS RT-N65U - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
Network / Transport Protocol
PPTP, L2TP, NTP, PPPoE, DHCP, DDNS
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
DMZ port, DHCP support, NAT support, VPN support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, URL filtering, parental control, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), IPSec passthrough, Samba support, static IP mode, DNS proxy, bandwidth control, IPv4 support, ASUS AiRadar
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, UPnP
AC 120/230 V ( 50/60 Hz )
17.2 cm x 14.5 cm x 6 cm
375 g
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
MPPE, 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Built-in Devices
USB Hub
Status Indicators
Power, WLAN, WAN, LAN, USB
WAN: 1 x RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
3
External power adapter
1 x network cable
17.2 cm
14.5 cm
6 cm
375 g
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.81
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.50
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.86
£15.94
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.66
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.47
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.74
£42.57
Scroll to top
