BT.com
Wishlist
Asus RAMPAGE V EXTREME/U3.1 S2011 Intel X99 DDR4 USB3.1 Bundled
Delivery
Standard 1-3 working days
Most powerful X99 motherboard with OC Panel and USB 3.1 Type-A (Dual) card bundled
  • Intel® Core™ i7 processors on LGA 2011-v3 socket
  • Intel X99 Express chipset
  • OC Socket, OC Panel, Safe Boot and ReTry buttons - Powerful tuning kit for breaking records
  • Extreme Engine Digi+ IV - Primo components for rock-steady power
  • DirectCU, X-Socket II, multiple thermal sensors and Fan Xpert 3 - Stay even cooler
  • PCI Express 3.0 x4 M.2, dual SATA Express, 3T3R 802.11ac Wi-Fi - Unparalleled connectivity with blistering-fast transfer speeds
  • SupremeFX 2014, Sonic Radar II, Intel Ethernet, LANGuard, GameFirst III, KeyBot, RAMDisk - Hear more, banish lag, accelerate loading and control
  • USB 3.1 Type-A Card (Dual) bundled
ASUS RAMPAGE V EXTREME/U3.1 - motherboard - extended ATX - LGA2011-v3 Socket - X99 - with ASUS USB 3.1 Type-A CARD
Motherboard - extended ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7, Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
Max RAM Size
64 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 2 x SATA Express port, 1 x M.2
USB / FireWire Ports
10 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Bundled with
Motherboard - extended ATX - with ASUS USB 3.1 Type-A CARD
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3300 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
SupremeFX
DTS Connect, High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x8, x8 mode; quad: x16, x8, x8, x8 mode; single card: x16 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 8 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 1 x SATA Express port
1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 10 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, SMBIOS 2.8 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, NVIDIA SLI Technology Support, ASUS Q-Design, ROG Connect, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS COP EX, ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, ASUS iROG, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, Loss-less content protection technology, ROG BIOS Print, ROG CPU-Z, NVIDIA 4-way SLI Technology Support, Voltiminder LED II, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Onboard Button, ASUS USB Charger+, ASUS Wi-Fi GO!, AMD 4-way CrossFireX technology support, DirectKey, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, ASUS SSD Secure Erase, Preboot eXecution Environment (PXE), Clear CMOS Button, ELNA Audio Capacitors, ASUS Fan Xpert 3, Dual Intelligent Processors 5, GameFirst III, LANGuard, Sonic Radar II, Sonic Studio, Sonic SenseAmp, Sonic SoundStage, KeyBot, ASUS Extreme Engine Digi+ IV, USB 3.1 Boost
ROG connect cable, ROG OC Panel Kit, ROG Door Hanger, ASUS 3T3R Wi-Fi moving aerials
10 x Serial ATA cable , 1 x SLI bridge , 1 x 3-way SLI bridge , 1 x 4-way SLI bridge , 1 x CrossFire cable
Software Included
Kaspersky Anti-Virus, ASUS EZ Flash 2, ASUS AI Charger+, ROG CPU-Z, ROG Mem TweakIt Utility, DAEMON Tools Pro Standard, ASUS WebStorage, ASUS AI Suite III, ROG RAMDisk, ASUS HomeCloud, ASUS Turbo App, ROG GameFirst III
Plug and Play, ACPI 5.0
30.5 cm
27.2 cm
Scroll to top
