BT.com
Wishlist
Asus Rampage III Extreme Intel X58, 1366, 6DDR3, 4PCI-Ex16, Full CrossfireX/SLI, USB3 & SATA6, ATX
Delivery
Standard Due date unavailable
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
CPU Feature
LGA1366 Intel® Core™ i7 Ready
This motherboard supports the latest Intel® Core i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. Supports Intel® QuickPath Interconnect (QPI) with a system bus of up to 6.4 GTs and a max bandwidth of up to 25.6 GBs. Intel® Core i7 processor is one of the most powerful and energy efficient CPUs in the world.
Chipset Features
Intel® X58 Chipset
The Intel® X58 Express Chipset is one of the most powerful chipset designed to support the Intel® Core™ i7 Processors with LGA1366 package and Intel® next generation system interconnect interface, Intel® QuickPath Interconnect (QPI), providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It also supports up to 36 PCI Express 2.0 lanes providing better graphics performance.
PCIe 2.0
Double Speed; Double Bandwidth
This motherboard supports the latest PCIe 2.0 devices for double speed and bandwidth which enhances system performance.
Multi-GPU Technology
SLI/CrossFireX On-Demand
Why choose when you can have both?
SLI or CrossFireX? Fret no longer because with the ROG Rampage III Extreme, you’ll be able to run both multi-GPU setups. The board features SLI/CrossFire on Demand technology, supporting up to four graphics cards in a 3-Way SLI or CrossFireX configuration. Whichever path you take, you can be assured of jaw-dropping graphics at a level previously unseen.
Memory Feature
Tri-Channel, DDR3 2200(O.C.) MHz
The motherboard supports DDR3 memory that features data transfer rates of 2200(O.C.) / 2133(O.C.) / 2000(O.C.) / 1800(O.C.) / 1600(O.C.) / 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The Triple-channel DDR3 architecture double the bandwidth of your system memory to boost system performance.
Future Transfer Technology
True USB 3.0 Support
10X faster date rates!
Experience ultra-fast data transfers at 4.8Gbps with USB 3.0—the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components.
True SATA 6Gb/s Support
Experience the future of storage!
Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems.
ASUS Rampage III Extreme Republic of Gamers - motherboard - ATX - LGA1366 Socket - X58
Motherboard - ATX
Chipset Type
Intel X58 Express / Intel ICH10R
Processor Socket
1 x LGA1366 Socket
Compatible Processors
Core i7 Extreme Edition, Core i7
Max RAM Size
24 GB
RAM Supported
6 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
9 x SATA, 1 x eSATA
USB Ports Configuration
11 x USB
FireWire Ports Configuration
2 x FireWire
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
Processor Socket
LGA1366 Socket
Max Processors Qty
1
Supported RAM
Max Size
24 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Speed
PC3-12800, PC3-10666, PC3-8500
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Triple channel memory architecture
Audio
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 6 x DIMM 240-pin , 4 x PCIe 2.0 x16 , 1 x PCIe x4 , 1 x PCI
Storage Interfaces
Intel ICH10R: SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , JMicron JMB363: SATA-300 -connectors: 1 x 7pin Serial ATA, 1 x 7pin external SATA - 2 devices , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
Intel Matrix RAID Technology
1 x PS/2 keyboard , 1 x TOSLINK , 1 x FireWire - 6 pin FireWire , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 7 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
1 x audio - 4 pin MPC
Additional Connectors (Optional)
2 x USB 2.0, 1 x IEEE 1394 (FireWire)
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, ASUS MyLogo3, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, BIOS FlashBack, USB BIOS Flashback
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, ROG Connect, Q-DIMM, Q-LED, Q-Slot, ProbeIt, ASUS Extreme Engine Digi+, RC Bluetooth, CrashFree BIOS 3, ASUS Q-Connector, ASUS Q-Fan Plus, Onboard Switch, ASUS Noise Filter, audio jack detect technology, ASUS CPU Level Up, ASUS COP EX, Voltiminder LED, NVIDIA 3-way SLI Technology Support, ASUS Extreme Tweaker, ASUS Loadline Calibration, Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, ASUS iROG, Intel QuickPath Architecture, Intel Turbo Boost Technology, AMD CrossFireX technology support
1 x 3-way SLI bridge , 1 x SLI bridge , 1 x CrossFire cable , 1 x Serial ATA cable , 1 x USB / eSATA panel
Software Included
Drivers & Utilities, ASUS Live Update, ASUS PC Probe 2, ASUS TurboV EVO Utility, Kaspersky Anti-Virus, ASUS AI Suite, Futuremark 3DMark Vantage Advanced Edition
Plug and Play, RoHS, ACPI 2.0a
30.5 cm
26.9 cm
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* what a board
Reviewed by ken on 23/01/2011
having been a socket 775 fan for many moons ive just gone over th 1366 this board the rampage 111 extreme is wonderful.and i would recomend this company BT to any body quick off the mark when you order and the girls on the other end of the phone are so polite and very helpfull
Scroll to top
