BT.com
Wishlist
Asus Radeon R7 360 OC 2GB GDDR5 PCIe3.0 Graphics Card
Delivery
Standard Due date unavailable
ASUS R7 360 is a super-cool graphics card with pumped gaming performance, perfected manufacturing, and strong fortification for extreme reliability and longevity. Powered by the advanced graphics-processing units (GPUs), this graphics card, packed with ASUS technologies, including dual-fan design, delivers greater air flow and quieter performance. This model also has AUTO-EXTREME technology with Super Alloy Power II for aerospace-grade quality and reliability, plus GPU Tweak II for intuitive performance tweaking.
ASUS R7360-OC-2GD5-V2 - graphics card - Radeon R7 360 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 360
2 GB GDDR5
Core Clock
1070 MHz
Effective Memory Clock
6 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
DVI-I (dual link) , DVI-D (dual link) , DisplayPort , HDMI
API Supported
OpenGL 4.4, DirectX 12
3.8 cm x 22 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 360
Core Clock
1070 MHz
Max Resolution
4096 x 2160
API Supported
Dual Slot Fan Cooler, Native HDMI, AMD Eyefinity Technology, Dual Fan Design, AMD CrossFireX Technology, FreeSync Technology, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6 GHz
Bus Width
128-bit
Additional Requirements
6 pin PCI Express power connector
150 Watt
Software Included
Display drivers, XSplit Gamecaster, ASUS GPU Tweak II, World of Warships invite code
3.8 cm
22 cm
11.1 cm
Scroll to top
