BT.com
Wishlist
Asus PRIME A320M-K AM4 AMD A320 DDR4 PCIe3.0 M.2 USB3.0 mATX
Delivery
Standard 3-5 working days
ASUS Prime is the next evolution of the ASUS motherboard, born of a pedigree that stretches back to 1989. The team of excellent engineers are passionate about empowering everyone to enjoy the benefits of customization and tuning, and the driving force behind the development of Prime is to make advanced enthusiast controls easily accessible - maximizing performance, stability and compatibility for great DIY PC experiences. Simply stated: it's time for Prime.
ASUS PRIME A320M-K - motherboard - micro ATX - Socket AM4 - AMD A320
Motherboard - micro ATX
Chipset Type
AMD A320
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
USB 3.0 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A320
Processor Socket
Socket AM4
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
2 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (with AMD Ryzen CPU); x8 mode (with AMD 7th Generation A-series/Athlon CPU)) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 1 x PS/2 keyboard , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse , 1 x VGA , 2 x USB 2.0 , 1 x HDMI
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header , 1 x audio - header , 1 x speaker - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ASUS EZ Flash 3, SMBIOS 3.0 support, ACPI 6.1 support
Hardware Features
ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, ASUS Fan Xpert, ASUS DIGI+ VRM, Fanless Design Heatsink, ASUS Stainless Steel Back I/O, LANGuard, ASUS Overvoltage Protection, Lighting Control, ASUS 5X Protection III, ASUS SafeSlot Core
1 x M.2 screw, I/O back cover
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III
Plug and Play
22.6 cm
22.1 cm
Scroll to top
