BT.com
Wishlist
Asus PB279Q 27" 3840x2160 5ms HDMI DisplayPort 4K LED Monitor
Delivery
Standard Due date unavailable
Open your eyes to breathtaking levels of detail with the ASUS PB279Q 4K UHD monitor. The PB279Q features a 16:9 aspect ratio WLED display that delivers 3840 x 2160 resolution 4K UHD visuals. With a pixel density of 163 pixels-per-inch (PPI), the PB279Q has over 8 million pixels, four times the pixel density of standard Full HD displays for astonishingly detailed visuals - allowing you to experience more onscreen real estate and stunning image clarity that have to be seen to be believed. The PB279Q features In-Plane Switching technology for 178-degree wide-viewing angles on both horizontal and vertical planes, as well as 100% sRGB wide color gamut for consistent color reproduction and true-to-life visuals.
ASUS PB279Q - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
72.7 kWh
Power Consumption (On mode)
49.8 W
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.15525 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort
Speakers
Integrated
Display Position Adjustments
62.49 cm x 22 cm x 40.77 cm
10 kg
3 years warranty
Display Type
Energy Class
Class C
72.7 kWh
49.8 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.15525 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Mobile High-Definition Link (MHL)
10 kg
Audio
Speakers - stereo - integrated
MHL / HDMI , DisplayPort , Mini DisplayPort
Mechanical
1 x audio cable , 1 x HDMI cable , 1 x DisplayPort cable
Power Supply
Internal
90 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years
Scroll to top
