BT.com
Wishlist
Asus PB278QR 27" 2560x1440 5ms VGA DVI HDMI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
The PB278QR offers a highly ergonomic and smart design that complies with tilt, pivot, swivel, and height adjustments to ensure an always-comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment. Premium 16:9 wide-format PB278QR LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true "what you imagine is what you create" power. HDMI, DisplayPort, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop.
ASUS PB278QR - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
53 kWh
Power Consumption (On mode)
36 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
64.3 cm x 21.8 cm x 55.23 cm
7.8 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, PSE Mark, GOST-R, J-MOSS, ErP Ready, TCO Displays 6.0
Display Type
Energy Class
Class B
53 kWh
36 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, input select, colour temperature
Picture in picture, picture by picture, Zero Bright Dot, HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), 100% sRGB colour gamut, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
64.3 cm x 21.8 cm x 55.23 cm - with stand
7.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2.5 Watt
HDMI , DisplayPort , Audio line-in , Headphones , DVI-D (dual link) , VGA
Mechanical
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x audio cable , 1 x DVI cable , 1 x VGA cable
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 64.3 cm - depth: 6.96 cm - height: 38.62 cm
ENERGY STAR Certified
Scroll to top
