BT.com
Wishlist
Asus PB248Q 24" 1920x1200 6ms VGA DVI HDMI DisplayPort IPS LED Monitor
Delivery
Standard Due date unavailable
The ASUS PB248Q features a 16:10 aspect ratio, A+ IPS LED-backlit panel for sRGB and NTSC color reproduction; additionally, along with a 178° wide viewing angle, it ensures quality visuals and minimal onscreen color shift from almost any viewing position. ASUS PB248Q also delivers ultra-smooth visuals thanks to a quick response time - ensuring users have a lag-free viewing experience when it comes to watching movies or playing games. Games played under the PB248Q are more vivid - as all details can be seen and true color can be shown with the PB248Q. The ergonomically-designed PB248Q professional monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
What's in the box
  • ASUS PB248Q
  • VGA cable
  • DVI cable
  • Audio cable
  • DisplayPort cable
  • USB cable
ASUS PB248Q - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A+
Energy Consumption per Year
29.1 kWh
Power Consumption (On mode)
19.9 W
Stereo speakers, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
55.72 cm x 23.5 cm x 41.63 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, NOM, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, WEEE, GOST-R, J-MOSS, ErP Ready, TCO Displays 6.0
Display Type
Energy Class
Class A+
29.1 kWh
19.9 W
Diagonal Size
24.1"
Viewable Size
24.1"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Gamma correction, input select, colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, ASUS QuickFit Virtual Scale, 100% sRGB colour gamut, 5-way Navigation Key, customisable OSD buttons
55.72 cm x 23.5 cm x 41.63 cm - with stand
6.6 kg
Audio
Speakers - stereo - integrated
VGA , DVI-D , Audio line-in , DisplayPort , HDMI , Headphones , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
65 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.1 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 55.72 cm - depth: 6.2 cm - height: 36.28 cm
ENERGY STAR Certified
Scroll to top
