BT.com
Wishlist
Asus PA238QR 23" 1920x1080 6ms HDMI DVI Monitor
Delivery
Standard Due date unavailable
Marketing description is not available.
What's in the box
  • ASUS PA238QR
  • VGA cable
  • DVI cable
  • DisplayPort cable
  • Software
ASUS PA238QR - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Presence sensor, USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
5.5 kg
Microsoft Certification
Compatible with Windows 7
3 years warranty
Display Type
Energy Class
Class B
38 kWh
26 W
Diagonal Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, gamma correction, input select, colour temperature
Picture in picture, picture by picture, HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Color Rich Technology
- with stand
5.5 kg
VGA (HD-15) , HDMI , DVI-D , DisplayPort , USB 2.0 upstream , 4 x USB 2.0 downstream , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, tilt adjustment, swivel adjustment, adjustable height, pivot adjustment
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
33 Watt
Power Consumption Stand by / Sleep
1 Watt
On / Off Switch
Included Software
Drivers & Utilities
Limited warranty - 3 years
Scroll to top
