Click to visit BT.com
BT.com
Wishlist
Asus P8Z77 WS S1155 Intel Z77 DDR3 ATX
Quicklinx: 821LWS00
Mfr#: P8Z77 WS
Essential accessories
P8Z77 WS: 50% Upgrade With Gen 3 Four-Way Graphics Power
  • Best Graphics Performance with Gen3 four-Way CrossFireX™ and Geforce® SLI™
  • Dual Server Class Intel® Gigabit LAN Lower CPU Utilization and Improve Throughput Quality
  • Up to 60% Hybrid Graphics Boost and 3X Faster Video Conversion with LucidLogix Virtu MVP
  • 3X Faster Performance with one-click ASUS SSD Caching
  • Fan Xpert 2 - The Most Customizable Fan Controls
The ASUS Workstation Series is the ideal foundation for a powerful PC. It delivers awesome power, dependable performance and unmatched multiple I/O scalability for the most demanding tasks and future upgrades. The ASUS Workstation Series intelligently reduces operating noise and dissipates heat through advanced and environmentally friendly methods to accommodate user needs. ASUS Workstation Series motherboards also bring you ultimate reliability and quality through 24x24 initiative, which means 24-hour non-stop operation and a 24-month life cycle supply guarantee so you don't change computers so often. Instead, let the ASUS Workstation Series improve the quality of your work and life.
ASUS P8Z77 WS - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID), 2 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 5 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC892
DTS Connect, High Definition Audio, DTS UltraPC II
LAN
Network Controller
2 x Intel 82574L
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 4 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9128 : SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 , SATA-600 -connectors: 2 x 7pin external SATA - 2 devices
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x DVI-I , 2 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
4 x USB 2.0 , 1 x USB 3.0 - header , 1 x USB 2.0 - Type A , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector, 4-pin auxiliary power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TurboV, ASUS WS Diag. LED, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), Intel Clear Video HD Technology, ASUS SSD Caching, USB 3.0 Boost, Dual Intelligent Processors 3, Fanless Design Heat-pipe, Q-Code, AMD Quad CrossFireX technology support, ASUS Fan Xpert 2, ASUS Network iControl, ASUS SMART DIGI+, ASUS USB Charger+, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, ASUS 2 Phase DRAM Power Design, Intel InTru 3D Technology, Intel Insider
6 x Serial ATA cable , 1 x 3-way SLI bridge , 1 x 4-way SLI bridge , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
3 years warranty
Service & Support Details
Limited warranty - 3 years
