BT.com
Wishlist
Asus P8Z77-V PRO S1155 Intel Z77 DDR3 ATX with Thunderbolt
Free delivery
Delivery
Standard Due date unavailable
P8Z77-V PRO/THUNDERBOLT: First-choice Thunderbolt™ Z77 Motherboard - Blistering-fast Data Transfers, Blazing Performance Boosts, and DLNA Streaming Made Easy
  • Dual Intelligent Processors 3 with SMART DIGI+ Power Control
  • SMART DIGI+ - Get a Blazing Performance Boost and CPU Wattage Requirements Cut in Half!
  • Thunderbolt onboard - Blistering-fast Data Transfer and Daisy Chain Expansion
  • Wi-Fi GO! - DLNA Streaming and Remote Desktop Made Easy
  • Fan Xpert 2 - The Most Customizable Fan Controls\
  • USB 3.0 Boost - Faster USB 3.0 Transmission with UASP(170%)
Thunderbolt™ Onboard
"Intel and Asus have worked closely on the implementation of Thunderbolt™ technology onto their motherboards", said Jason Ziller, Intel's Director of Thunderbolt Marketing. "It is our pleasure to state the P8Z77-V PREMIUM is the first Thunderbolt certified motherboard in the industry, a testament to its solid design and compatibility."
An industry first, ASUS has placed Thunderbolt I/O technology onboard, and are set to revolutionize the speed at which peripherals and displays operate. Featuring a maximum bi-directional speed of 10 Gbps, Thunderbolt is 2 times faster than USB 3.0 and an incredible 20 times faster than USB 2.0. And with the ability to daisy-chain up to six devices without the need for a hub or switch, that means less overheard for a clutter free computing experience. For example, users can connect multiple native Thunderbolt storage devices, an HD video capture device and even an HD display to a single Thunderbolt chain while maintaining maximum throughput. You can also connect a DisplayPort, DVI, HDMI or VGA display with an existing adapter
LGA1155 Intel® 3rd/2nd Generation Core™ i7/ Core™ i5/ Core™ i3/ Pentium® / Celeron® Processors Ready
This motherboard supports Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world.
Intel® Z77 Express Chipset
The Intel® Z77 Express Chipset is a single-chipset design to support socket 1155 Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z77 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel® Z77 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
Quad-GPU SLI and Quad-GPU CrossFireX Support!
Flexible Multi-GPU Solutions, Your Weapon of Choice! P8Z77-V PRO brings you the multi-GPU choice of either SLI™ or CrossFireX. The motherboard features the most powerful Intel® Z77 platform to optimize PCIe allocation in multiple GPU configurations. Expect a brand-new gaming style you've never experienced before!
Dual Intelligent Processors 3 with SMART DIGI+ Technology
The world's first Dual Intelligent Processors from ASUS pioneered twin onboard chips - TPU (TurboV Processing Unit) and EPU (Energy Processing Unit). Dual Intelligent Processors 3 builds on that foundation with new SMART DIGI+ power control, which includes multiple digital voltage controllers, allowing ultra-precise tuning for the CPU, iGPU and DRAM. It's upgraded with one-click extreme performance optimization and selectable CPU wattage levels, offering easier power control and better power savings with the user-friendly AI Suite II utility.
TPU plus SMART DIGI+ TPU with the All-New SMART DIGI+ for a Blazing Performance Boost
Always at the forefront of power design, ASUS propels you into the future standard of power management again by SMART DIGI+ Technology, which works with the TPU (TurboV Processing Unit) to ramps up performance to its maximum. Enable the all-new SMART DIGI+ key with a single click and adjust CPU ratios manually in the TPU to increase CPU frequency up to an incredible 85%!
CPU Wattage Cut in Half!
SMART DIGI+ Technology also includes the Smart CPU Power Level profile, which reduces CPU power consumption to a specific indicated wattage with a single click, creating a cooler and quieter PC. With next generation Intel® VRD 12.5 future power technology, ASUS once again leaps to the future of innovation.
USB 3.0 Boost: Faster USB 3.0 Transmission with UASP
New ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol), the latest USB 3.0 standard. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to an already impressive fast USB 3.0 transfer speed. ASUS software automatically accelerates data speeds for compatible USB 3.0 peripherals without the need for any user interaction. > Click Here to Learn More
  • World's 1st USB 3.0 UASP Support - 170% faster instantly
  • Complete USB 3.0 Solution - Performance boost for most USB devices
  • Simple Plug & Boost - Auto detection design ensures best performance always
USB BIOS Flashback: Simple Plug & Press - Hardware-based BIOS Flashback
A truly revolutionary hardware-based update solution. USB BIOS Flashback offers the most convenient way ever to update the BIOS! It allows users to update new UEFI BIOS versions even without hardware such as a CPU or DRAM installed into the motherboard. Just plug in a USB flash drive containing the BIOS file, and press the BIOS Flashback button for 3 seconds with the power supply connected. The UEFI BIOS will then automatically update without requiring further interaction. With its new, complementary Windows application, users can regularly check for UEFI BIOS updates and download the latest BIOS automatically. Hassle-free updating for the ultimate convenience!
PCIe 3.0 Ready
The latest PCI Express bus standard delivers improved encoding for twice the performance of current PCIe 2.0. Total bandwidth for a x16 link reaches a maximum of 32GB/s, double the 16GB/s of PCIe 2.0 (in x16 mode). PCIe 3.0 provides users unprecedented data speeds, combined with the convenience and seamless transition offered by complete backward compatibility with PCIe 1.0 and PCIe 2.0 devices. It's a must-have feature for PC users aiming to improve and optimize graphics performance, as well as have the latest, most future-proof technology.
ASUS P8Z77-V PRO/THUNDERBOLT - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600, 4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 3.0 + ( 2 x USB 3.0 + 10 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
802.11b/g/n, Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz
Speed
PC3-12800, PC3-10600
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC892
DTS Connect, High Definition Audio, DTS UltraPC II
LAN
Network Controller
Intel 82579V
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 2 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x Thunderbolt , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
10 x USB 2.0 , 1 x USB 3.0 - header , 1 x serial , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, 12 Phase Power Design, ASUS Q-Design, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TurboV, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), Fanless Design Heatsink, USB 3.0 Boost, Dual Intelligent Processors 3, ASUS 8 Phase CPU Power Design, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Fan Xpert 2, ASUS Network iControl, ASUS SMART DIGI+, ASUS USB Charger+, ASUS Wi-Fi GO!, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, ASUS 2 Phase DRAM Power Design
External antenna, ASUS Wi-Fi GO! card
4 x Serial ATA cable , 1 x SLI bridge , 1 x USB / eSATA panel
Software Included
Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Limited warranty - 3 years
Scroll to top
