Asus P8Z77-V DELUXE S1155 Intel Z77 DDR3 ATX
Standard Due date unavailable
P8Z77-V DELUXE: Your Next Z77 Build with Blazing Performance Boosts, Customizable Fan Controls and Remote Control Functions over Wi-Fi
  • Dual Intelligent Processors 3 with SMART DIGI+ Power Control
  • SMART DIGI+ - Get a Blazing Performance Boost and CPU Wattage Cut in Half!
  • Wi-Fi GO! - DLNA Streaming and Remote Desktop Made Easy
  • Fan Xpert 2 - The Most Customizable Fan Controls
  • USB 3.0 Boost - Faster USB 3.0 Transmission with UASP
  • Quad-GPU SLI and Quad-GPU/3-Way CrossFireX Support!
The P8Z77-V Deluxe with a 32GB DDR3 memory and PCLe 3.0, features the new Intel Z77 express chipset and supports a 22/32 nm CPU providing excellent overclocking capabilities of up to 2600 MHz. It also caters to a wide range of end users by including features such as GeForce® SLI™ and AMD Crossfire for a flawless architecture accommodating the power of up to four graphics cards, whether that be for professional graphics work, heavy duty multimedia or dedicated gaming. While dual Intel® Ethernet provides precise network traffic management and Wi-Fi GO! offers functions such as DLNA streaming, so users can enjoy content from a variety of devices for more a convenient entrainment experience.
The P8Z77-V Deluxe also includes Dual Intelligent Processors 3 and Smart Digi+ consisting of two onboard chips, the TPU and EPU. This also consists of multiple digital voltage controllers that allow for ultra-precise tuning of CPU, iGPU and DRAM power delivery, including an 85% CPU frequency boost, while working with the TPU to ramp up performance to full potential for the ultimate user experience. Another incredible feature is Fan Xpert 2 which enables the most customizable fan controls ever offered on a motherboard. While another ASUS exclusive feature includes the UEFI BIOS with a multi-language setting offering a mouse controlled and user friendly interface which can be upgraded using BIOS USB flashback, complete within just one click!
Containing DisplayPort and HMDI for graphics output as well as 8 USB 3.0 ports with USB boost UASP for unprecedented speed, the P8Z77-V Deluxe also features LudicLogix Virtu MVP which boots responsiveness, improves gaming frame rates by 30-70%, sharpens visual quality and works seamlessly with hundreds of game stations. Impressively the P8Z77-V Deluxe also has SSD caching which provides SSD speed with HDD capacity so users can plug in their SSD/HDD and complete the caching with just one click, experiencing speed with ease. Thus making The P8Z77-V Deluxe a multifaceted motherboard for excellent quality, speed and performance!
Asus Exclusive Innovations
  • SMART DIGI+ Power Control
  • ASUS Wi-Fi GO!
  • ASUS Wi-Fi GO! Remote
  • Fan Xpert 2
  • USB BIOS Flashback
  • USB 3.0 Boost
  • ASUS SSD Caching
  • 100% Japan-made Solid Capacitors
  • ASUS Anti-Surge Protection
  • GeForce® SLI™ - dramatically improves graphic performance
  • Quad GPU AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
  • Intel® Ethernet - provides precise network traffic management
  • LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
Spec details
  • Model P8Z77-V DELUXE
  • Chipset Z77
  • Power Phase SMART DIGI+ / Digital 16+4 Phase design / DIGI+ DRAM
  • Graphics 2PCIe 3.0 x16 slots (1@x16 or dual@x8); 1PCIe 2.0x16
  • LucidLogix Virtu MVP YES
  • SLI/CrossFire SLI/CrossFireX
  • PCI N/A
  • PCIex1 4
  • Storage 4SATA 6Gb/s / 4SATA 3Gb/s / 2*eSATA
  • LAN 2*Gb LAN (one is high quality Intel LAN)
  • USB 8USB 3.0 / 8USB 2.0
  • Wi-Fi Support ready in back I/O / Wi-Fi 802.11 a/b/g/n / Dual band 2.4/5GHz & Bluetooth v4.0
  • Audio ALC898 (w/DTS)
  • Accessories 4SATA 6G cable, 2SATA 3G cable, 2Wi-Fi antenna 2.4/5GHZ, 1SLI bridge, 1ASUS Q-Shield, 1Q-connector
  • Form Factor ATX
ASUS P8Z77-V Deluxe - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
4 x SATA-600 (RAID), 4 x SATA-300 (RAID), 2 x eSATA-600
USB / FireWire Ports
6 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
HD Audio (8-channel)
802.11a/b/g/n, Bluetooth, 2 x Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio Codec
Realtek ALC898
DTS Connect, High Definition Audio, DTS UltraPC II
Network Controller
Intel 82579V / Realtek RTL8111F
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 4 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9128: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 , SATA-600 -connectors: 2 x 7pin external SATA - 2 devices
RAID Features
Intel Smart Response Technology
1 x HDMI , 1 x DisplayPort , 2 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 6 x USB 3.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
4 x USB 2.0 , 1 x USB 3.0 - header , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, Onboard Switch, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TurboV, 20 Phase Power Design, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), Intel Clear Video HD Technology, Intel Smart Response Technology, ASUS SSD Caching, USB 3.0 Boost, Dual Intelligent Processors 3, Fanless Design Heat-pipe, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS Fan Xpert 2, ASUS Network iControl, ASUS SMART DIGI+, ASUS USB Charger+, ASUS Wi-Fi GO!, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, ASUS 2 Phase DRAM Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video
ASUS Wi-Fi GO! card, 2 x Wi-Fi Ring Moving Antennas
6 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS Auto Tuning, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Asus P8Z77-d Deluxe Mobo
Reviewed by S. Gyde on 07/06/2013
This Motherboard is outstanding. O/C's will find they have total control. A Bluetooth issue was solved by a BIOS update (with Asus help). Heck that BIOS up-date was easy to do. If you have a K series chip, you can just dial in the multiplier with the +&- keys to overclock. You will need a better cpu cooler than Intel supply. The on-board sound quality is astonishing. And I'm not easily pleased here. Just for once, the bundled software is useful. No, I don't work for Asus. I am just happy with this mobo.
Scroll to top
