BT.com
Wishlist
Asus P8Z77-M S1155 Intel Z77 DDR3 mATX
Delivery
Standard Due date unavailable
The P8Z77-M with a 32GB DDR3 memory and PCLe 3.0, features the new Intel Z77 express chipset and supports a 22/32 nm CPU providing excellent overclocking capabilities of up to 2400 MHz. It also caters to a wide range of end users by including features such as AMD Crossfire for a flawless architecture accommodating the power of up to four graphics cards, whether that be for professional graphics work, heavy duty multimedia or dedicated gaming and Network iControl to perfectly manage bandwidth.
The P8Z77-M also includes Dual Intelligent Processors 2 consisting of two on-board chips, the TPU and EPU providing precise Vcore PWM, integrated graphics voltages and frequency module adjustments with minimal power loss. While the ASUS DIGI+ VRM digital power design empowers users with superior flexibility and perfect precision to ensure optimized performance, extreme system stability and greater power efficiency. Other incredible features include Fan Xpert+ which enables customizable fan controls and the ASUS exclusive UEFI BIOS with a multi-language setting offering a mouse controlled and user friendly interface which can be upgraded using BIOS USB flashback, complete within just one click!
Furthermore, containing 2 USB 3.0 ports with USB boost UASP which gains unprecedented speed, the P8Z77-M also features LudicLogix Virtu MVP which boots responsiveness, improves gaming frame rates by 30-70%, sharpens visual quality and works seamlessly with hundreds of game stations. Thus making The P8Z77-M a multifaceted motherboard for excellent quality and value!
Asus Exclusive Innovations
  • DIGI+ VRM
  • Fan Xpert+
  • Network iControl
  • USB BIOS Flashback
  • USB 3.0 Boost
Innovations
  • Dual Intelligent Processors 2 - with New DIGI+ Power Control include three digital voltage controllers, allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control
  • AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
  • LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
Spec details
  • CPU LGA1155 socket for Intel® 3rd/2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors, Supports 22/32nm CPU, Supports Intel® Turbo Boost Technology 2.0* * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
  • Chipset Intel® Z77 Express Chipset
  • Memory: 4 x DIMM, max. 32GB, DDR3 2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1600/1333 MHz, non-ECC, un-buffered memory, Dual channel memory architecture, Supports Intel® Extreme Memory Profile (XMP) * Hyper DIMM support is subject to the physical characteristics of individual CPUs. Please refer to Memory QVL(Qualified Vendors List) for details.
  • Expansion Slots 1 x PCI Express 3.0*/2.0 x16 slots (at x16), 1 x PCI Express 2.0 x16 slot [black] (run at x4 mode, compatible with PCIe x4, x1 devices), 1 x PCI Express 2.0 x1 slots, 1 x PCI * PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
  • VGA Integrated Graphics Processor- Intel® HD Graphics support, Multi-VGA output support: HDMI/DVI-D/RGB port, Supports HDMI with max. resolution 1920 x 1200@60Hz, Supports DVI-D with max. resolution 1920 x 1200@60 Hz, Supports RGB with max. resolution 2048 x 1536@75 Hz, Supports Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™, Maximum shared memory of 1696MB
  • Multi-GPU support Supports LucidLogix Virtu MVP Technology* Supports AMD® CrossFireX™ Technology, * LucidLogix Virtu MVP supports Windows 7 operating systems.
  • Storage Intel® Z77 Express Chipset, 2 x SATA 6.0 Gb/s ports (gray) with RAID 0, 1, 5, 10 support, 4 x SATA 3.0 Gb/s ports (blue) with RAID 0, 1, 5, 10 suppors, Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology* * Supports on Intel® Core™ processor family with Windows 7 operating systems.
  • LAN Realtek® 8111F Gigabit LAN controller
  • Audio Realtek® ALC887 8-channel audio CODEC*, Supports jack-detection, multi-streaming, front panel jack-retasking, Optical S/PDIF out port at back I/O, *Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
  • USB Intel® Z77 Express Chipset- supports ASUS USB 3.0 Boost Turbo Mode.* 2 x USB 3.0/2.0 ports at mid-board for front panel support 2 x USB 3.0/2.0 ports at back panel(blue) Intel® Z77 Express Chipset, 10 x USB 2.0/1.1 ports (6 ports at mid-board, 4 ports at back panel), * The USB 3.0 ports run USB 3.0 speed under Windows® 7 or later versions.
  • ASUS Unique Features: ASUS Digital Power Design, ASUS DIGI+ VRM, ASUS Exclusive Features, ASUS EPU , ASUS TurboV, Network iControl , USB 3.0 Boost
  • ASUS Exclusive Overclocking Features, Precision Tweaker 2 / vCore: Adjustable CPU voltage at 0.005V increment / vDRAM Bus: 127-step Memory voltage control / vPCH: 177-step Chipset voltage control / iGPU: 238-step iGPU voltage control / SFS (Stepless Frequency Selection) BCLK/PCIE frequency tuning from 80MHz up to 300MHz at 0.1MHz increment
  • Back Panel I/O Ports 1 x HDMI port, 1 x DVI-D port, 1 x RGB port, 1 x Optical S/PDIF out, 1 x LAN (RJ45) ports, 2 x USB 3.0/2.0 ports, 4 x USB 2.0/1.1 ports (blue, 1 supports USB BIOS Flashback), 1 x PS/2 keyboard/mouse combo port, 3 Audio jacks support 8 channel*, *Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
  • Internal I/O Connectors 1 x USB 3.0/2.0 connector supports additional 2 USB ports (19-pin), 3 x USB 2.0/1/1 connectors support additional 6 USB ports, 2 x SATA 6.0Gb/s connectors ( 2 x gray), 4 x SATA 3.0Gb/s, connectors (blue), 1 x CPU Fan connector (4-pin), 3 x Chassis Fan connectors (4-pin), Front panel audio connector (AAFP), 1 x S/PDIF out header, 24-pin EATX Power connector, 8-pin EATX 12V Power connector, System Panel(Q-Connector), 1 x MemOK! button, 1 x BIOS Flashback button, 1 x Clear CMOS jumper 1 x TPM header, 1 x COM port,
  • BIOS 64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
  • ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
  • Accessories 1 x Serial ATA 6.0Gb/s cables, 1 x Serial ATA 3.0Gb/s cables, 1 x I/O Shield, 2 in 1 Q-connector, User's manual
  • Support DVD Drivers, ASUS Utilities, ASUS Update , Anti-virus software (OEM version)
  • Form Factor uATX Form Factor, 9.6"x 9.6" (24.4cm x 24.4cm)
ASUS P8Z77-M - motherboard - micro ATX - LGA1155 Socket - Z77
Motherboard - micro ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
1696 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1696 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 2 x USB 3.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x USB 3.0 - header , 1 x serial , 1 x audio , 1 x SPDIF out
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, ASUS 4+1 Phase Power Design, ASUS TurboV, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, Fanless Design Heatsink, USB 3.0 Boost, ASUS Fan Xpert+, AMD CrossFireX technology support, ASUS Network iControl, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Suite II, ASUS AI Charger, ASUS Update
Plug and Play, ACPI 2.0a
24.4 cm
24.4 cm
Limited warranty - 3 years
Scroll to top
