Asus P8Z68-V/GEN3 S1155 Intel Z68 DDR3 ATX
Standard Due date unavailable
P8Z68-V/GEN3: Fully PCI-Express 3.0 Ready, Intel Z68 motherboard. USB 3.0 Boost includes world's first UASP support.
  • Dual Intelligent Processors 2 with DIGI+ VRM Digital Power Design
  • UEFI BIOS (EZ Mode) - Flexible & Easy BIOS Interface
  • LucidLogix® Virtu (Universal Switchable Graphics) - Auto Switching between Integrated Graphics and NVIDIA/AMD Cards
  • Intel® Smart Response Technology - SSD Speed with HDD Capacity
  • BT GO! (Bluetooth) - Diverse BT Enjoyment, New Technology Lifestyle
  • GPU Boost - Push the Limits with iGPU Level Up!
  • Quad USB 3.0 Support - Double Access, Double Convenience
  • Quad-GPU SLI and Quad-GPU CrossFireX Support!
PCI Express® 3.0
PCI Express® 3.0 (PCIe 3.0) is the latest PCI Express bus standard with improved encoding schemes that provide twice the performance of current PCIe 2.0. Total bandwidth for a x16 link reaches a maximum of 32GB/s, double the 16GB/s of PCIe 2.0 (in x16 mode). As such, PCIe 3.0 provides users unprecedented data speeds, combined with the convenience and seamless transition offered by complete backward compatibility with PCIe 1.0 and PCIe 2.0 devices. PCIe 3.0 will become a must-have feature for users who wish to improve and optimize graphic performance, as well as have the latest technology available to them. * Actual PCIe 3.0 speed varies with the installed CPU type.
UEFI BIOS (EZ Mode): Flexible & Easy BIOS Interface
Exclusive to ASUS motherboards, its UEFI (Unified Extensible Firmware Interface) is the first ever mouse-controlled graphical BIOS interface designed with dual selectable modes. It delivers a user-friendly interface that goes beyond traditional keyboard-only BIOS controls to enable more flexible and convenient input with quick scrolling. Users can easily navigate the UEFI BIOS with the smoothness of their operating system. Quick and simple overclocking and setup sharing is facilitated by the F12 hotkey BIOS snapshot feature. The exclusive EZ Mode displays frequently-accessed setup info, while the Advanced Mode is for experienced performance enthusiasts that demand far more intricate system control, including detailed DRAM information.
Intel® Smart Response Technology: SSD Speed with HDD Capacity
Intel® Smart Response Technology boosts overall system performance. It uses an installed fast SSD (min 18.6GB available capacity) as a cache for frequently accessed data. Harness the combination of SSD-like performance and response with hard drive capacity, that's 4X faster than a HDD-only system. * Support Intel® Smart Response Technology on 2nd generation Intel® Core™ processor family
ASUS P8Z68-V/GEN3 - motherboard - ATX - LGA1155 Socket - Z68
Motherboard - ATX
Chipset Type
Intel Z68 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 4 x SATA-300 (RAID), 1 x eSATA-300
USB / FireWire Ports
2 x USB 3.0 + 6 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
HD Audio (8-channel)
Bluetooth, Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
Intel Z68 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture
Audio Codec
Realtek ALC892
High Definition Audio
Network Controller
Intel 82579
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 2 x PCIe x1 , 2 x PCI
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , JMicron JMB362: SATA-300 -connectors: 1 x 7pin external SATA - 1 devices
RAID Features
Intel Smart Response Technology
1 x DVI-D , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 6 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
2 x USB 3.0 , 6 x USB 2.0 , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, NVIDIA Quad SLI Technology Support, ASUS TurboV, ASUS BT GO!, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, 16 Phase Power Design, Lucid Virtu, Fanless Design Heatsink, AMD Quad CrossFireX technology support
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS Live Update, ASUS AI Suite II, ASUS AI Charger+
Plug and Play, ACPI 2.0a, ErP Ready
30.5 cm
24.4 cm
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good Motherboard
Reviewed by Reflection on 25/11/2011
this motherboard has all you will need at a good price too PCI Express 3.0 UEFI Bios + Intel smart response so you don't have to buy a big SSD to get fast Hard Drive speed's as it can use the ssd as a big hard drive cache. The motherboard was as easy as 1 2 3 to set up and to overclock is just like a b c, easy just make sure you have some good cooling as my i7 2600k was easy to put at 4.4GHZ on this motherboard but had to back it off as I need a better CPU cooler. I would recommend this board to any one on a budget first class as always A** Cheers **
5* Great motherboard
Reviewed by Ron on 05/03/2012
Fantastic board. Nice EFI bios interface. Lots of options and features including some bluetooth software for connection to android and streaming audio which was a nice surprise. Lots of usb 2.0 and 3.0 aswell as a full complement of sata ports.
The automatic overclocking features are a bit lax and seem to cause the board to crash but that is easily resolved by setting up the overclocking manually. Currently running i7 2700k at 4.6ghz comfortably using this board.
Reviewed by Rob on 24/01/2012
Great system board. Have always used ASUS motherboards so no unexpected surprises.
Very well spec'd, being a GEN3 with Ivybridge support is big bonus.
Only minor point is that I should have got the Pro for more sata ports! 6 not enough for me. Still very pleased with.
Scroll to top
