Asus P8H77-M S1155 Intel Z77 DDR3 mATX
Standard Due date unavailable
The P8H77-M with a 32GB DDR3 memory and PCLe 3.0, features the new Intel H77 express chipset and supports a 22/32 nm CPU providing excellent overclocking capabilities of up to 2200 MHz. It also caters to a wide range of end users by including features such as AMD Crossfire for a flawless architecture accommodating the power of up to four graphics cards, whether that be for professional graphics work, heavy duty multimedia or dedicated gaming and Network iControl to perfectly manage bandwidth.
The P8H77-M also includes Dual Intelligent Processors 2 consisting of two onboard chips, the TPU and EPU providing precise Vcore PWM, integrated graphics voltages and frequency module adjustments with minimal power loss. The EPU is also part of Protect 3.0 which safeguards devices by preventing overvoltage damage and contains an anti-surge protection design while also eliminating 50% of radiation. While the ASUS DIGI+ VRM digital power design empowers users with superior flexibility and perfect precision to ensure optimized performance, extreme system stability and greater power efficiency. Other incredible features include Fan Xpert+ which enables customizable fan controls and the ASUS exclusive UEFI BIOS with a multi-language setting offering a mouse controlled and user friendly interface which can be upgraded using BIOS USB flashback, complete within just one click!
Furthermore, containing 4 USB 3.0 ports with USB boost UASP which gains unprecedented speed, the P8H77-M also features LudicLogix Virtu MVP which boots responsiveness, improves gaming frame rates by 30-70%, sharpens visual quality and works seamlessly with hundreds of game stations. While GPU Boost accelerates the integrated GPU for extreme graphics performance and stable system-level upgrades. Thus making The P8H77-M a multifaceted motherboard for excellent quality and value!
Asus Exclusive Innovations
  • Fan Xpert+
  • Network iControl
  • USB BIOS Flashback
  • USB 3.0 Boost
  • Dual Intelligent Processors 3 - with New DIGI+ Power Control include three digital voltage controllers, allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control
  • Quad GPU AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
  • LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
Spec details
  • Model P8H77-M
  • Chipset H77
  • Power Phase DIGI+VRM, 4+1+1 Phase
  • Memory 4*DIMM,2200(O.C.)
  • Graphics 1PCIe 3.0 x16 slot / 1PCIe 2.0 x16 slot (@x4)
  • LucidLogix Virtu MVP YES
  • SLI/CrossFire CrossFireX
  • PCI 1
  • PCIex1 1
  • Storage 2SATA 6Gb/s / 4SATA 3Gb/s
  • LAN 1*Realtek Gb LAN
  • USB 4USB 3.0 / 10USB 2.0
  • Audio ALC887 8-CH
  • TPM Header 1
  • COM Header 1
  • Accessories 2*SATA 6G cable
  • Unique Features DIGI+ VRM / Network iControl / USB 3.0 Boost / GPU Boost / Fan Xpert / Protect 3.0
  • Form Factor uATX, 24.4cm x 24.4cm
ASUS P8H77-M - motherboard - micro ATX - LGA1155 Socket - H77
Motherboard - micro ATX
Chipset Type
Intel H77 Express
Processor Socket
1 x LGA1155 Socket
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture
Audio Codec
Realtek ALC887
High Definition Audio
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 4 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x USB 3.0 - header , 6 x USB 2.0 , 1 x serial , 1 x SPDIF out , 1 x parallel , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, ASUS TurboV, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, ASUS Protect 3.0 Technology, USB 3.0 Boost, AMD Quad CrossFireX technology support, ASUS Network iControl, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, 4+1+1 Phase Power Design
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS Update
Plug and Play, ACPI 2.0a
24.5 cm
24.5 cm
Scroll to top
