Asus P8H61-MX R2.0, Intel PDC G2020 & 4GB XMS3 Value Bundle
Standard Due date unavailable
Exclusive Self-Build Special Bundle
Perfect Entry Level PC!
Take the fear out of Self-Build with this tested Intel Value Bundle! We test it so you don't have to! Motherboard, CPU and Memory - Boxed & Ready To Rock!
Asus AMD P8H61-MX R2.0 Motherboard: Cost attractive model for H61 uATX
  • PCIe 3.0 - Improve your graphic performance with incredible data speed.
  • GPU BOOST - Go to the Limit with iGPU Level Up !
  • UEFI BIOS (EZ Mode) - Flexible & Easy BIOS Interface
  • Anti Surge - Full-time Power Guardian-Make System Free From Risk
This motherboard supports the Intel processor in LGA1155 package with memory and PCI Express controllers integrated to support 2-channel (2 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes. This provides great graphics performance.
The motherboard supports DDR3 memory that features data transfer rates of 1333/1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance.
The Intel® H61(B3) Express Chipset is the latest single-chipset design to support the new 1155 socket Intel® 3rd/2nd generation processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability.
The latest PCI Express bus standard delivers improved encoding for twice the performance of current PCIe 2.0. Total bandwidth for a x16 link reaches a maximum of 32GB/s, double the 16GB/s of PCIe 2.0 (in x16 mode). PCIe 3.0 provides users unprecedented data speeds, combined with the convenience and seamless transition offered by complete backward compatibility with PCIe 1.0 and PCIe 2.0 devices.
Intel Pentium Dual Core G2020 2.9GHz S1155 3MB (BX80637G2020)
The Intel Pentium processor delivers great desktop and mobile performance, low power enhancements, and multitasking for everyday computing.
  • Model - Pentium G2020
  • Socket - 1155
  • Frequency - 2.9GHz
  • Cores - 2
  • Threads - 2
  • L3 Cache - 3MB
Corsair 4GB (1x4GB) DDR3 1600Mhz CL11 XMS3 Performance Desktop Memory Module (CMX4GX3M1A1600C11)
Corsair's mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair's new XMS heat spreaders, each module is built using carefully selected RAMs.
  • One 4GB modules for use in high performance for the Intel Core i7, i5 and i3 Dual Channel systems
  • Outrageously fast 1600MHz performance using 4GB of memory
  • Low 11-11-11-30 latency
  • 10 Years Manufacturers Warranty
  • Density: 4GB (1x4GB Module)
  • Speed: 1600MHz
  • Timing: 11-11-11-30
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.50V
  • Warranty: 10 Years Manufacturers Warranty
ASUS P8H61-MX - 2.0 - motherboard - micro ATX - LGA1155 Socket - H61
Motherboard - micro ATX
Chipset Type
Intel H61 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
4 x SATA-300
USB / FireWire Ports
6 x USB 2.0 + ( 2 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H61 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
16 GB
Bus Clock
2200 MHz, 2000 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture
Audio Codec
High Definition Audio
Network Controller
Realtek RTL8111F-VB-CG
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices
1 x PS/2 keyboard / mouse , 1 x DVI-D (dual link) , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 6 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
2 x USB 2.0 - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, ASUS EFI BIOS, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASUS Q-Fan 2, ASUS Anti-Surge Protection, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, ASUS Fan Xpert, ASUS Network iControl
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Suite II, ASUS AI Charger, ASUS Update
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
18.3 cm
Scroll to top
