BT.com
Wishlist
Asus P8B75-M S1155 Intel B75 DDR3 mATX
Delivery
Standard Due date unavailable
ASUS P8B75-M features ASUS Fan Xpert. ASUS Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature, which is caused by different climate conditions in different geographic regions and system loading. Built-in variety of useful profiles offer flexible controls of fan speed to achieve a quiet and cool environment.
ASUS P8B75-M - motherboard - micro ATX - LGA1155 Socket - B75
Motherboard - micro ATX
Chipset Type
Intel B75 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
1 x SATA-600, 5 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Chipset Type
Intel B75 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
1024 MB
Audio
Audio Codec
VIA VT1708S
High Definition Audio
LAN
Network Controller
Realtek RTL8111F-VB-CG
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x4 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 1 x 7pin Serial ATA - 1 devices , SATA-300 -connectors: 5 x 7pin SATA - 5 devices
1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 2 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack
Internal Interfaces
2 x USB 3.0 , 4 x USB 2.0 , 1 x serial , 1 x parallel , 1 x SPDIF out , 1 x audio
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
ASUS Q-Fan 2, jack retasking, ASUS Anti-Surge Protection, MemOK!, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, USB 3.0 Boost, ASUS Network iControl, Lucid Virtu MVP, Intel Small Business Advantage support
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger, ASUS Update
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
24.4 cm
22.6 cm
Limited warranty - 3 years
Scroll to top
