BT.com
Wishlist
Asus P8B75-M LX PLUS S155 Intel B75 DDR3 mATX
Delivery
Standard Due date unavailable
This motherboard supports the Intel ivy bridge processors in the LGA1155 package, with memory and PCI Express controllers integrated to support 2-channel DDR3 memory and 16 PCI Express 2.0 lanes. This provides great graphics performance. Intel ivy bridge processors are among the most powerful and energy efficient CPUs in the world.
The Intel B75 express is the latest single-chipset design that supports the new socket 1155 Intel Core i3/Core i5/Core i7 processors. It improves performance by utilizing serial point-to-point links, allowing for increased bandwidth and stability. Additionally, the P8B75-M LX PLUS comes with 1 SATA 6 Gbps and 5 SATA 3 Gbps ports for faster data retrieval, doubling the bandwidth of current bus systems.
ASUS P8B75-M LX PLUS - motherboard - micro ATX - LGA1155 Socket - B75
Motherboard - micro ATX
Chipset Type
Intel B75 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
1 x SATA-600, 5 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
Max Allocated RAM Size
1696 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel B75 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
2200 MHz, 2000 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
1696 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111F-VB-CG
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCI , 1 x CPU , 2 x DIMM 240-pin
Storage Interfaces
SATA-600 -connectors: 1 x 7pin Serial ATA - 1 devices , SATA-300 -connectors: 5 x 7pin SATA - 5 devices
1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
2 x USB 3.0 , 4 x USB 2.0 , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, ASUS EFI BIOS, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, Conductive Polymer Capacitors, USB 3.0 Boost, ASUS Network iControl, Intel Small Business Advantage support
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger, ASUS Update
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
24.4 cm
17.5 cm
Scroll to top
