Click to visit BT.com
BT.com
Wishlist
Asus N600 Dual Band Ethernet Adapter
Quicklinx: 84KYWS00
Mfr#: EA-N66
Wired / Wireless: Wireless
Protocol: IEEE 802.11n
Form Factor: External
Compatibility: PC
Type: Radio access point
Standard delivery Delivered within 3-5 working days
9 in stock
£73.12
Thanks to ASUS innovation, the EA-N66 presents the world's first versatile 3-in-1 dual-band 450Mbps Access Point/ Wi-Fi Bridge/ Range Extender with powerful performance and a truly exhilarating design. The stylish pyramid shape offers both artistic merit and a practical approach to technology, embedded with orthogonally-arranged antennas to lessen interference and boost signal coverage. Dual operating bands meet diverse needs for every user segment, while easy mode switching via the new interface lets you turn the device into different modes at will.
Unique Antennas
Patent orthogonal 3x3 antenna design
With the unique orthogonal arrangement of the three antennas designed by ASUS RD, EA-N66 is developed to prevent any interference between each antenna, boosting the coverage to the extreme.
Silver & black Pyramid with blue LED
ASUS presents the unprecedented design to the world, expressing the idea of space age and future technology. The distinctively rippled pattern signifies an excellent wide networking coverage of EA-N66.
Extreme Dual-band Speed
Selectable dual-band N900 data throughput
The dual-band operating mode can satisfy both normal and power user: with 2.4GHz, web surfing or e-mail delivery will be brisk, and when HD streaming or blu-ray movie are needed, the 5GHz band provides a blazingly fast lag-free home entertainment.
Access Point (AP) Mode
Create or upgrade your wireless home network.
Just connect the EA-N66 via an existing Ethernet cable and create home Wi-Fi networks with selectable 2.4GHz/5GHz bands. Get speedy and smooth networking, with dual-band operation connecting more devices wirelessly. The 2.4GHz band supports daily tasks like web browsing, while clearer 5GHz allows ultra-fast and stable online gaming, HD streaming, and heavy downloading. Each band works at up to 450Mbps!
Bridge Mode
Instant wireless for all your Ethernet devices!
The ASUS EA-N66 is compatible with any devices with Ethernet support, including smart TVs, multimedia players, games consoles, and your PC. WPS allows you to connect to your Wi-Fi router with a single button press.
Range Extender Mode
Expend your existing Wi-Fi network's coverage.
The ASUS EA-N66 can expand the range of your home's existing Wi-Fi network. Now you can enjoy trouble-free wireless networking in your backyard, garage, or attic.
Ultimate Performance
Extend your existing Wi-Fi network's coverage.
ASUS-patented antennas and high-quality components ensure wide-cover stable Wi-Fi even in multi-floor locations.
Easy Setup
Simply switch modes and build your networks
New user-friendly ASUS interface gives you neat and streamlined control, so network settings, mode switching, and device configuration are extra-easy.
Header / Product Line
ASUS
Header / Manufacturer
ASUSTeK COMPUTER
Wired / Wireless
Wireless
Radio access point
Speed
450 Mbps
Standards
IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Networking / Wireless Protocol
802.11 a/b/g/n
Header / Packaged Quantity
1
Networking / Ports Qty
1
Miscellaneous / Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-Enterprise, WPA-PSK, WPA2-Enterprise, WPA2-PSK
Dimensions & Weight / Height
6.2 cm
Header / Model
EA-N66
External
Networking / Remote Management Protocol
HTTP
Aerial / Aerial Form Factor (F)
Internal integrated
Compatibility
PC, Mac, Unix
Dimensions & Weight / Width
12.2 cm
Dimensions & Weight / Depth
11.1 cm
Dimensions & Weight / Weight
110 g
Asus N600 Dual Band Ethernet Adapter Bundle deal on Asus N600 Dual Band Ethernet Adapter
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£83.11
saving £4.99
84KY C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £5.97
84KY C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.91
84KY C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.40
84KY C2G 2m Cat6a Shielded Patch - Blue In Stock £8.96
84KY C2G TruLink Media Gateway RJ45 Cap In Stock £0.70
84KY C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £56.59
Compatibility: PC
Brand: Asus
Price Range Inc VAT: 50 - 100
