BT.com
Wishlist
Asus N3050M-E micro ATX Intel Celeron N305 USB 3.0 Gigabit LAN
Asus N3050M-E micro ATX Intel...
£59.41
£59.41
Add to wishlist
Delivery
Standard Due date unavailable
These motherboards are proven to be compatible with more than 1,000 components and devices, and undergo a minimum of 7,000 hours of strict validation. That gives you the peace of mind of knowing that ASUS motherboards are fit for all environments and applications. To build your PC with the best foundations, build it with an ASUS motherboard.
ASUS N3050M-E - motherboard - micro ATX - Intel Celeron N3050
Motherboard - micro ATX
Intel Celeron N3050 (Dual-Core)
Max RAM Size
8 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600
USB / FireWire Ports
2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 2.0 via headers)
Graphics
Intel HD Graphics
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Supported RAM
Max Size
8 GB
DDR3
Bus Clock
1600 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
Intel HD Graphics
512 MB
Audio
Audio Codec
Realtek ALC887-VD2
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
2 x DIMM 240-pin , 2 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x1 mode)
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
2 x USB 2.0 , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x PS/2 keyboard , 1 x VGA , 1 x PS/2 mouse , 1 x parallel , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
2 x USB 2.0 - header , 1 x serial - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, UEFI BIOS, ACPI 5.0 support, SMBIOS 2.8 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, All-Solid Capacitor motherboard Design, ASUS Fan Xpert, Fanless Design Heatsink, USB 3.0 Boost, Intel Smart Connect Technology, Low EMI Solution, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, LANGuard
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version)
Plug and Play, ACPI 5.0
22.6 cm
17.8 cm
Scroll to top
