BT.com
Wishlist
Asus MX279H 27" LED IPS Monitor 1920x1080 VGA Dual HDMI
Asus MX279H 27" LED IPS Monitor...
£263.89
Beauty Beyond Boundaries Full HD IPS LED-backlit & Frameless Monitor
15 in stock
£263.89
Add to wishlist
Delivery
Standard 1-3 working days
Beauty Beyond Boundaries: Full HD AH-IPS LED-backlit and Frameless Monitor
  • Full HD AH-IPS LED display with 178° wide-view angle in frameless design for edge-to-edge brilliance
  • ASUS SonicMaster Technology, co-developed with Bang & Olufsen ICEpower® for premium immersive audio
  • Featuring dual HDMI ports for multi device connections
  • Good Design Award Winner for its ultra-slim, ergonomic design with sturdy sundial-inspired stand
Inspired by millennia of artistic legacy, the Designo MX series sports an elegant and precision-crafted sundial design. The MX279H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ technology for incredible visuals. In addition, built-in ASUS SonicMaster technology, co-developed with Bang & Olufsen ICEpower, delivers immersive premium audio performance.
Designo MX279H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology - delivering improved color accuracy plus increased energy efficiency.
The Designo MX279H features ASUS SonicMaster technology - which was co-developed by the ASUS Golden Ear team and Bang & Olufsen ICEpower. This ASUS-exclusive audio technology combines advanced hardware and software to refine every acoustic detail in pristine quality to deliver crystal clear, true-to-life surround sound - reproducing richer and more distinct vocals at a wider frequency range and louder volumes.
ASUS MX279H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
33.7 kWh
Power Consumption (On mode)
23.1 W
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Black, silver
62.26 cm x 22.52 cm x 44.13 cm
5.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, GOST-R, J-MOSS
Display Type
Energy Class
Class A+
33.7 kWh
23.1 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, MobileSound 3 technology
Black, silver
62.26 cm x 22.52 cm x 44.13 cm - with stand
5.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
VGA , 2 x HDMI , DVI-D , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), ASUS SonicMaster, Bang & Olufsen ICEpower
1 x HDMI-DVI cable , 1 x VGA cable , 1 x audio cable
37 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.5 Watt
ENERGY STAR Certified
Other bundles
Asus MX279H 27
Asus MX279H 27" LED IPS Monitor 1920x1080 VGA Dual...
£263.89
TP Link Smart Plug
Save £0.98
£288.88
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Impressive
Reviewed by Dave on 23/07/2013
It is great, Brilliantly bright and whites are whitest I have seen on a monitor. Colours look very true. I would say the very light touch on the buttons is annoying sometimes. But the rest of the functions on this monitor are awwesome
5* Very Pleased
Reviewed by Barry on 05/09/2015
I bought this monitor because I do a lot of photographic editing and was finding my old 22 inch HP monitor hard to work with and one or two pixels had blown. BT delivered the MX279H earlier than expected (no complaints there). On unpacking I found it was very straight forward to put the stand together ans mount the monitor. It was then a simple mater of plugging it into the mains and hooking it up to the PC via one of the HDMI ports. Bingo I was up and running. The buttons for adjusting the screen setting are situated on the bottom edge of the screen and are very sensitive. The Bang and Oulfsen sound is perfectly adequate to play my music collection through while working. Overall I have found this to be a very good value monitor.
5* Large and crystal clear
Reviewed by Muarrif on 13/06/2014
This is an excellent monitor with very sharp image. Very happy with the performance
4* Incorrect Cable plugs
Reviewed by Anonymous on 27/03/2014
Does not come with a British Plug for the Asus power adapter make sure you get a european plug.
Scroll to top
