BT.com
Wishlist
Asus ML249H 24" Full HD Super Slim LED Monitor
Delivery
Standard 1-3 working days
178° of Vertical and Horizontal Ultra Wide Viewing Angle
  • MVA panel wiith 178° wide viewing angle
  • 50,000,000:1 ultra high ASUS Smart Contrast Ratio
  • Good Design award winner with ultra-slim profile
178°Ultra Wide Viewing Angle
ML249H adopts 178°(H) / 178°(V) ultra wide viewing angle MVA panel that eliminates color shift on your screen no matter where and how you look at it
50,000,000:1 ASUS Smart Contrast Ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images
Full HD with HDMI
Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port
Ultra-slim Profile
Alluring high glossy piano-black finish makes the ML Series the centerpiece of every living space.
Ring Stand with Ergo-Fit II Technology
Sleek geometric design combines straight lines and curves with an ultra-slim profile.
LED Touch-Sensor Buttons
Intuitively adjust the monitor´s settings with a simple touch of its LED sensor buttons.
ASUS ML249H - LCD monitor - 24"
LCD monitor - 24"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Swivel, tilt
57.2 cm x 22 cm x 43.1 cm
4.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, PSE Mark, GOST-R, J-MOSS, ErP Ready
3 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
24"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Controls & Adjustments
Brightness, contrast, input select, colour temperature
Ultra Slim Design, HDCP, LED-backlit, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS Ergo-Fit II Technology
4.2 kg
VGA , Headphones , HDMI
Mechanical
Swivel, tilt
Tilt Angle
25
1 x VGA cable , 1 x HDMI-DVI cable
Power Supply
External
39 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Limited warranty - 3 years
Scroll to top
