BT.com
Wishlist
Asus MAXIMUS VIII EXTREME Intel Z170 LGA1151 DDR4 ATX Motherboard
Asus MAXIMUS VIII EXTREME Intel...
£229.99
Hurry, only 1 left in stock!
£229.99
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Friday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
You'd never win with your eyes closed, so open your ears up to the best audio for the battlefield! ROG's awesome audio expertise is the result of extensive R&D, and SupremeFX 2015 is the crystal-clear result - onboard sound as superior as your gaming rep. Greater performance means smoother gameplay - and that means more chance to win. With the best overclocking (OC) design, UEFI BIOS and intuitive OC gadget and utility, you'll enjoy unmatched performance - coupled with an exclusive cooling design ensures your system never breaks a sweat. Get your hands on OC Panel II, an intuitive system monitoring and tweaking in two modes. For both, a clear 2.6-inch display keeps you informed and in full control - so you can maximize the available power. OC Panel II also comes with the illuminated LED on the stunning ROG logo. OC Panel II can also be used as external overclocking console, giving easy access to multiple ROG-exclusive features including Subzero Sense, VGA Hotwire, Slow Mode and Pause Switch. You also have direct access to two PWM and two full-speed fan headers, as well as remote power and reset buttons. Thought you'd taken overclocking as far as it could go? Meet ASUS Pro Clock, a dedicated base-clock (BCLK) generator designed for 6th-generation Intel processors that ramps BCLK frequencies up to 400MHz or even beyond . This custom solution works in tandem with the ASUS TurboV Processing Unit (TPU) to enhance voltage and base-clock overclocking control - providing an exciting another way to boost performance to extremes.
Second-generation ASUS T-Topology pushes DDR4 memory overclocking to over 3866MHz with all memory slots populated - and that means the best-ever gaming performance from your Maximus VIII Extreme rig! Featuring a customized trace layout for reduced crosstalk and coupling noise, second-generation T-Topology ensures time-aligned signal transfer for improved memory stability and compatibility. The smoothest, slickest mouse-controlled graphical BIOS has been improved to make it even more gorgeous. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced Modes help you find your way, quickly and easily. ROG's uniquely-intelligent technology effectively caches an entire storage device so that favorite games and apps launch at breakneck speeds, getting to work the moment it's activated. RAMCache turns milliseconds into microseconds to boost game-load times to stratospheric levels, and minimizes risk of data loss! As a gamer you demand stability and durability, so ROG integrates long-lasting, premium components, plus exclusive smart DIY designs across the board - ensuring the best gaming experiences.
ASUS MAXIMUS VIII EXTREME - motherboard - extended ATX - LGA1151 Socket - Z170
Motherboard - extended ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600, 2 x SATA Express port, 1 x M.2, 1 x U.2 port
USB / FireWire Ports
USB 3.0, USB 3.1, USB-C 1 x USB-C + 3 x USB 3.1 + 4 x USB 3.0 + (4 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3500 MHz (O.C.), 3800 MHz (O.C.), 3866 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
512 MB
Audio
Audio Codec
SupremeFX 2015
DTS Connect, High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual: x8 mode; triple: x8, x4, x4 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2, 2 x SATA Express port, 1 x U.2 port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
Intel Rapid Storage Technology
1 x HDMI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 3 x USB 3.1 , 1 x USB-C , 4 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
6 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
EZ Plug, jack retasking, MemOK!, ASUS Q-Design, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS COP EX, ASUS Q-Shield, ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS iROG, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, Intel Clear Video HD Technology, Intel Smart Response Technology, ROG VGA Hotwire, ROG Subzero Sense, Q-Code, SupremeFX Shielding technology, ASUS DIGI+ Power Control, ASUS Wi-Fi GO!, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, AMD 4-way CrossFireX technology support, Disk Unlocker, ASUS SSD Secure Erase, Preboot eXecution Environment (PXE), Debug LED, ASUS Fan Xpert 3, Dual Intelligent Processors 5, LANGuard, Sonic Radar II, Sonic SenseAmp, USB 3.1 Boost, ASUS PRO Clock Technology, Sonic Studio II, KeyBot II, GameFirst IV, OptiMOS MOSFET, overclocking protection
ROG Door Hanger, cable labels, 1 x M.2 screw, ASUS 3T3R Wi-Fi moving aerials, I/O back cover, fan extension card, ROG fan stickers, ROG OC Panel II Kit
8 x Serial ATA cable , 1 x SLI bridge , 1 x CrossFire cable
Software Included
Drivers & Utilities, Kaspersky Anti-Virus (1 year subscription), ASUS AI Charger+, ROG CPU-Z, ROG GameFirst Utility, ROG Mem TweakIt Utility, ASUS WebStorage, ASUS AI Suite III, ROG RAMDisk, ASUS Turbo App, DAEMON Tools Pro Standard (1 year), Mobo Connect, PC Cleaner, Media Streamer, HyStream, ASUS RAMCache, Overwolf
Plug and Play
30.5 cm
27.2 cm
Scroll to top
