BT.com
Wishlist
Asus Maximus VI Impact S1150 Intel Z87 DDR3 mITX
Delivery
Standard Due date unavailable
Mini-ITX Z87 gaming board from ROG with amazing audio, incredible power management and flexible next-generation connectivity
  • LGA1150 socket for 4th Generation Intel®Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
  • Intel® Z87 Express Chipset
  • Impact Power- Compact dynamo of full-scale power
  • SupremeFX Impact- Blade of sound adds striking game audio
  • Sonic Radar- Scan and detect to dominate
  • mPCIe Combo II + Wi-Fi 802.11ac/Bluetooth 4.0- Extra connections with new gen support
  • GameFirst II + Intel LAN- Put Your Frags First
  • RAMDisk- Double up on speed with RAM
ROG mini-ITX, accept no compromises: ROG hits the road with mini-ITX - size is no longer any indicator of performance.
They said it couldn't be done, but ROG's devoted crew of designers and engineers has finally delivered on the dream of a proper mini-ITX gaming board. Fans of LAN parties and gaming tournaments love to make a strong impression -- and that's why more gamers choose Maximus VI Impact. Balancing great performance with excellent stability, power efficiency and thermal innovation, Maximus VI Impact fits in highly elegant and portable home-theater PC (HTPC) and Shuttle-style compact cases while retaining ROG's renowned cachet - so being a champion is more flexible than ever. or couch-bound living room champion becomes easier than ever.
Designed and tested for the best compatibility
Case and CPU-cooler compatibility is extremely important for mini-ITX gamers and enthusiasts. That's why ROG has performed hundreds of tests and modifications to perfect Maximus VI Impact's layout to ensure maximum compatibility with both mini-ITX chassis designs and CPU coolers.
  • Installation washers included* For convenience and the widest backplate compatibility, Maximus VI Impact includes four installation washers. * Washers required only if you encounter installation difficulties.
  • Zero height on backplate area. ROG designers carefully designed the Maximus VI Impact's layout to keep the CPU's blackplate area clear, allowing better support.
Impact Power: Compact dynamo of full-scale power
ROG engineers have reshaped Extreme Engine Digi+ III with Impact Power with a vertical design, so now you can benefit from precise power management and stable overclocking on mini-ITX - you get same best-quality components and vaunted overvolting and overclocking flexibility you expect from any ROG motherboard.
SupremeFX Impact: Blade of sound adds striking 115dB SNR (signal-to-noise ratio) audio
Experience outstanding 115dB signal-to-noise ratio audio on mini-ITX from the included SupremeFX Impact sound card - and keep the PCIe x16 slot free for an amazing graphics card.
Music PnP (Plug and Play) Amplify your audio
This brand-new, ROG-exclusive technology forwards a stereo audio stream straight to your speakers -- when your PC is turned off. Just connect an audio-playing device to the mic-in jack and let the music play.*
The benefits of Music PnP:
  • No-hassle -- hook-up with a 3.5mm jack cable
  • No power -- power-saving with your PC off*
  • No waiting -- your speakers will pump instantly
  • Requires analog-audio front-panel (AAFP) port to be connected to the case's HDA module
Perfect Voice
  • Upgraded noise cancellation: Simple and effective technology greatly improves internet calls (VoIP) with crystal-clear communications and no additional array microphones needed.
  • Noise gate: Exclusive digital signal processing removes noise during pauses in speech and other periods of silence.
  • Noise reduction: Spectral-subtraction algorithm analyzes and determines the amount of ambient noise to be countered.
mPCIe Combo II: with 802.11ac/Bluetooth 4.0: Extra connections with M.2 (NGFF) support
The next evolution of the mPCIe Combo card gives you even better expandability with the latest standards in connectivity and easy install. You get mini PCI Express 2.0 plus USB 2.0 with an included dual-band 2.4GHz/5GHz Wi-Fi 802.11ac and Bluetooth 4.0 module, powered by ASUS-exclusive Wi-Fi GO! Remote and Wi-Fi Engine, which maximize performance for better experiences. It's an instant upgrade to the fastest wireless right on your desktop. All without having to sacrifice a PCI Express slot!
The compact but versatile mPCIe Combo II further future-proofs your build with M.2 (NGFF, Next Generation Form Factor) connectivity for SSDs. M.2 is a fast and power-efficient standard that aims to replace mPCIe and mSATA, designed to optimize SSD performance. mPCIe Combo II works with your high speed M.2 SSDs and makes the most of their potential, helping you reduce load times to run your OS and games even faster.
Dual Intelligent Processors 4 with 4-Way Optimization: One click for better performance, efficiency, digital power control, reduced noise, and improved cooling.
Starting with the Turbo Processing Unit (TPU), 4-Way Optimization performs Auto Tuning, which automatically overclocks the CPU to within ~95% of its potential, a process that typically could take up to 2 days to manually overclock. Auto Tuning is even able to overclock 2 cores at a time, and can configured to prioritize either multiplier (default) or BLCK if desired.
The process then moves to the Energy Processing Unit (EPU), which customizes power saving profiles for periods of light use or idle states. Within this module are options to set a TDP cap for low power scenarios, as well as selectively shut off SATA and USB ports when idling.
Next, DIGI+ VRM optimizes digital power settings to take full advantage of the CPU's built-in digital power delivery, creating a more precise and stable overclocking experience through OCP and LLC presets.
Finally, Fan Xpert 2 tests and calibrates each individual case fan connected to your motherboard to create selectable cooling profiles that can be further customized upon completion. The ability to assign customized fan curves and/or all-or-nothing temperature thresholds to profiles is also included.
ASUS MAXIMUS VI IMPACT - motherboard - mini ITX - LGA1150 Socket - Z87
Motherboard - mini ITX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
4 x SATA-600 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 2 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 3000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
SupremeFX Impact
DTS Connect, High Definition Audio
LAN
Network Controller
Intel I217V
Network Interfaces
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x Mini PCIe
Storage Interfaces
SATA-600 -connectors: 4 x 7pin SATA, 1 x 7pin eSATA, 1 x M.2 - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Q-Design, ROG Connect, Q-DIMM, ASUS EZ DIY, Q-LED, ProbeIt, CrashFree BIOS 3, audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, Loss-less content protection technology, Intel Clear Video HD Technology, Intel Smart Response Technology, ROG BIOS Print, USB 3.0 Boost, ASUS 8 + 2 Phase CPU Power Design, Q-Code, SupremeFX Shielding technology, ASUS DIGI+ Power Control, ASUS Fan Xpert 2, ASUS USB Charger+, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, DirectKey, GameFirst II, Disk Unlocker, Dual Intelligent Processors 4, ASUS SSD Secure Erase, Sonic Radar, ELNA Audio Capacitors, ROG Pulse
2 aerials, ROG connect cable, mPCIe Combo II expansion card
4 x Serial ATA cable
Software Included
Drivers & Utilities, Kaspersky Anti-Virus, ASUS EZ Flash 2, ASUS AI Charger+, ROG CPU-Z, ROG Mem TweakIt Utility, DAEMON Tools Pro Standard, ASUS WebStorage, ASUS AI Suite III, ROG RAMDisk, ROG GameFirst II
Plug and Play, ACPI 2.0a
17 cm
17 cm
Scroll to top
