BT.com
Wishlist
Asus MAXIMUS VI GENE S1150 Intel Z87 DDR3 mATX
Delivery
Standard Due date unavailable
Asus Maximus VI Gene Z87-Plus High Performance Z87 chipset mainboard, ROG in MATX form.
This motherboard supports Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors in the LGA1150 package, with iGPU, memory and PCI Express controllers integrated to support on-board graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 MHz memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world.
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset features both the USB 3.0 & SATA6Gb technology for faster data retrieval speed. Moreover, Intel® Z87 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
  • Fan Expert2 - customize Fan speeds
  • Digi+VRM - Precise Over Clocking
  • USB BIOS Flash Back - Easy Bios Updates
  • USB 3.0 Boost - Fast Data Transfer
  • EPU - Green Energy saving
  • New UEFI Bios Design.
ASUS MAXIMUS VI GENE - motherboard - micro ATX - LGA1150 Socket - Z87
Motherboard - micro ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600
USB / FireWire Ports
6 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 2200 MHz, 2000 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz, 2800 MHz, 3000 MHz, 2600 MHz, 2666 MHz, 2500 MHz, 2933 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
SupremeFX (AD1988B)
DTS Connect, High Definition Audio
LAN
Network Controller
Intel I217V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 2.0 x4 , 1 x Mini PCIe
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x HDMI , 1 x LAN (Gigabit Ethernet) , 6 x USB 3.0 , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, 8+2 Phase Power Design, ASUS Q-Design, ROG Connect, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, audio jack detect technology, ASUS CPU Level Up, ASUS Q-Shield, ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, GPU.DIMM Post, Intel Clear Video HD Technology, ROG BIOS Print, USB 3.0 Boost, Q-Code, SupremeFX Shielding technology, AMD Quad CrossFireX technology support, ASUS USB Charger+, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, Dual Intelligent Processors 4, ASUS Extreme Engine Digi+ III, ASUS SSD Secure Erase
I/O back plate, mPCIe Combo II expansion card, ROG Door Hanger
1 x SLI bridge , 6 x Serial ATA cable
Software Included
Drivers & Utilities, Kaspersky Anti-Virus, ASUS EZ Flash 2, ROG CPU-Z, ROG Mem TweakIt Utility, DAEMON Tools Pro Standard, ASUS WebStorage, ASUS AI Suite III, ROG RAMDisk, ROG GameFirst II
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
24.4 cm
24.4 cm
Scroll to top
