Click to visit BT.com
BT.com
Wishlist
Asus Maximus VI Formula S1150 Intel Z87 DDR3 ATX
Quicklinx: 8X9GWS00
Mfr#: MAXIMUS VI FORMULA
Essential accessories
The unbeatable Z87 gaming board with double-sided ROG Armor, 23C-degrees cooler CrossChill and 120dB SNR, 600ohm audio
Maximus VI Formula series is the ultimate ATX gaming motherboard. Why? Just count the reasons. ROG's sixth-generation Formula packs even greater cooling performance, the very best onboard audio, incredible strength, amazing heat dissipation and advanced shielding technology. With ultrafast Intel® Ethernet plus attention to design that goes right down to the level of audio capacitors and amplifiers, the Maximus VI Formula arms you with gaming-dominating advantages that other motherboards just can't match -- that's why it's the winning formula.
  • LGA1150 socket for 4th Generation Intel®Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
  • Intel® Z87 Express Chipset
  • CrossChill - Great on air. Cooler with water
  • SupremeFX Formula - Amazing 120dB signal-to-noise ratio, 600ohm audio
  • ROG Armor - Style, strength, and cooling in one
  • Sonic Radar - Scan and detect to dominate
  • mPCIe Combo II With Wi-Fi - Extra connections with new gen support
  • Extreme Engine Digi+ III - Hardcore power delivery with premium components
  • GameFirst II + Intel LAN - Put Your Frags First
  • RAMDisk - Double up on speed with RAM
CrossChill hybrid thermal design: Great on air. 23°C Cooler with water
Choose between air or water cooling: it works with both! Unlike competing hybrid thermal solution, CrossChill requires no fan, so there's no noise or dust build-up. For those who do venture into water cooling, you can achieve up to 23°C lower MOSFET temperatures for more stable overclocking! Internally the water channel fins help to maximize the surface area for heat transfer, and thanks to its G1/4 threaded fittings, CrossChill even fits into any existing setup! Don't settle for a second-best solution.
SupremeFX Formula delivers premium sound card quality. Combining SupremeFX Shielding technology through physical PCB isolation, grounding separation and EMI cover shielding, while premium components such as ELNA® audio capacitors and German-made WIMA® film capacitors deliver audiophile grade performance. Lossless audio quality is ensured thanks to differential circuit design with high-fidelity operational amplifiers (op-amps) and Cirrus Logic® CS4398 headphone digital/analog converter (DAC) delivering a brilliant 120dB signal-to-noise ratio (SNR). Finally the Texas Instruments® TPA6120A2 600ohm headphone amplifier is able to boost every sound detail.
Perfect Voice
  • Upgraded noise cancellation: Simple and effective technology greatly improves internet calls (VoIP) with crystal-clear communications and no additional array microphones needed.
  • Noise gate: Exclusive digital signal processing removes noise during pauses in speech and other periods of silence.
  • Noise reduction: Spectral-subtraction algorithm analyzes and determines the amount of ambient noise to be countered.
Sonic Radar: In-game sound visualization overlay
Dedicated to FPS gamers, Sonic Radar is a stealthy overlay that shows you what opponents and teammates are up to. Gunshots, footsteps, and call-outs appear with precise directioning via the on-screen radar. Includes a hotkey that allows you to switch sound detection focus for specific effects within games, and intuitive settings that provide greater gaming experiences:
  • Four optimized game presets: three fine-tuned presets based on major FPS games, plus one general preset, all ready for your arena of engagement.
  • Six key sound effects detected: visualize major game sound effects to help you complete your mission every time.
ROG Armor: Style, strength, and cooling in one
100% exclusive to ASUS, the ROG Armor is more than just a stylish addition to the ultimate gaming motherboard, it contains two parts; a strong ABS top cover that blocks the heat from graphics cards directly to achieve lower system temperature as well as DIYers can apply their own personal style to, and a fortifying SECC steel support behind the PCB to prevent bending. It also ducts heat away from crucial components via thermal pads.
Extreme Engine Digi+ III: Hardcore power delivery with premium components
Completely digital architecture attains total control over the Fully Integrated Voltage Regulators (FIVR) of Intel® processors to supply the highest stability and precision for the CPU and memory. The design features dynamic speed adjustments alongside intricate manual controls that allow you to push processors and RAM beyond their limits.
Power components are also upgraded. NexFET MOSFETs handle up to 90% efficiency in high current delivery under normal operation and better durability in half the size of standard MOSFETs. Exclusive BlackWing chokes remain cool even when sizzling with as much as 60 amps of power with 3-5°C lower temps and minimal-loss power delivery. Japan-made 10K Black Metallic capacitors last five times longer and deliver 20% greater extreme temperature endurance than generic solid state capacitors, easily standing up to hardcore demands.
mPCIe Combo II with 802.11ac/Bluetooth 4.0: Extra connections with M.2 (NGFF) support
The next evolution of the mPCIe Combo card gives you even better expandability with the latest standards in connectivity and easy install. You get mini PCI Express 2.0 plus USB 2.0 with an included dual-band 2.4GHz/5GHz Wi-Fi 802.11ac and Bluetooth 4.0 module, powered by ASUS-exclusive Wi-Fi GO! Remote and Wi-Fi Engine, which maximize performance for better experiences. It's an instant upgrade to the fastest wireless right on your desktop. All without having to sacrifice a PCI Express slot!
The compact but versatile mPCIe Combo II further future-proofs your build with M.2 (NGFF, Next Generation Form Factor) connectivity for SSDs. M.2 is a fast and power-efficient standard that aims to replace mPCIe and mSATA, designed to optimize SSD performance. mPCIe Combo II works with your high speed M.2 SSDs and makes the most of their potential, helping you reduce load times to run your OS and games even faster.
Dual Intelligent Processors 4 with 4-Way Optimization: One click for better performance, efficiency, digital power control, reduced noise, and improved cooling.
Starting with the Turbo Processing Unit (TPU), 4-Way Optimization performs Auto Tuning, which automatically overclocks the CPU to within ~95% of its potential, a process that typically could take up to 2 days to manually overclock. Auto Tuning is even able to overclock 2 cores at a time, and can configured to prioritize either multiplier (default) or BLCK if desired.
The process then moves to the Energy Processing Unit (EPU), which customizes power saving profiles for periods of light use or idle states. Within this module are options to set a TDP cap for low power scenarios, as well as selectively shut off SATA and USB ports when idling.
Next, DIGI+ VRM optimizes digital power settings to take full advantage of the CPU's
ASUS MAXIMUS VI FORMULA - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600
USB / FireWire Ports
6 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2500 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 3000 MHz (O.C.), 3100 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
SupremeFX Formula
DTS Connect, High Definition Audio
LAN
Network Controller
Intel I217V
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 3.0 x16 ( dual: x8 mode; triple: x8, x4, x4 mode; single card: x16 mode ) , 3 x PCIe 2.0 x1 , 1 x Mini PCIe
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA, 1 x M.2 - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061 : SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
RAID Features
Intel Smart Response Technology
1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 6 x USB 3.0 , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, ASUS EZ Flash 2, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0a support
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Q-Design, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Extreme Tweaker, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, Loss-less content protection technology, Intel Clear Video HD Technology, Intel Smart Response Technology, ROG BIOS Print, USB 3.0 Boost, ASUS 8 + 2 Phase CPU Power Design, Q-Code, SupremeFX Shielding technology, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Fan Xpert 2, ASUS USB Charger+, ASUS Wi-Fi GO!, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Front Audio Headphone Amplifier, DirectKey, GameFirst II, Disk Unlocker, AMD Memory Profile (AMP) support, Dual Intelligent Processors 4, ASUS Extreme Engine Digi+ III, ASUS SSD Secure Erase, Sonic Radar, ROG Armor, CrossChill, NexFET
External antenna, I/O back plate, mPCIe Combo II expansion card, ROG Door Hanger, ROG cable lables
8 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, Kaspersky Anti-Virus, ASUS EZ Flash 2, ASUS AI Charger+, ROG CPU-Z, ROG Mem TweakIt Utility, DAEMON Tools Pro Standard, ASUS WebStorage, ASUS AI Suite III, ROG RAMDisk, ROG GameFirst II
Plug and Play, ErP Ready, ACPI 5.0a
30.5 cm
24.4 cm
