Standard Due date unavailable
Asus ROG Maximus VI Extreme Z87-Plus High Performance Z87 chipset mainboard, the mainboard that actually overclocked overclocking!
This motherboard supports 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors in the LGA1150 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world.
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel® Z87 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
  • Fan Expert2 - customize Fan speeds
  • Digi+VRM - Precise Over Clocking
  • USB BIOS Flash Back - Easy Bios Updates
  • USB 3.0 Boost - Fast Data Transfer
  • EPU - Green Energy saving
  • New UEFI Bios Design.
ASUS MAXIMUS VI EXTREME - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600
USB / FireWire Ports
6 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
HD Audio (8-channel)
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
2400 MHz, 2200 MHz, 2000 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz, 2800 MHz, 3000 MHz, 2600 MHz, 2666 MHz, 2500 MHz, 2933 MHz
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio Codec
Realtek ALC1150
High Definition Audio
Network Controller
Intel I217V
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 5 x PCIe 3.0 x16 ( dual x8 mode; triple: x16, x8, x8 mode; quad: x16, x8, x8, x8 mode; single card: x16 mode ) , 1 x PCIe 2.0 x4 , 1 x Mini PCIe
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 6 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x DisplayPort
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, 8+2 Phase Power Design, ASUS Q-Design, ROG Connect, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, CrashFree BIOS 3, audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, Intel Clear Video HD Technology, Intel Smart Response Technology, ROG BIOS Print, USB 3.0 Boost, ASUS ROG Extreme OC, ROG VGA Hotwire, ROG Subzero Sense, Q-Code, AMD CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Fan Xpert 2, ASUS USB Charger+, ASUS Wi-Fi GO!, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, Dual Intelligent Processors 4, ASUS Extreme Engine Digi+ III, ASUS SSD Secure Erase
External antenna, I/O back plate, Bluetooth / Wi-Fi module, ROG connect cable, mPCIe Combo II expansion card, ROG OC Panel Kit
1 x 3-way SLI bridge , 10 x Serial ATA cable , 1 x 4-way SLI bridge , 1 x SLI bridge , 1 x CrossFire cable
Software Included
Drivers & Utilities, Kaspersky Anti-Virus, ASUS EZ Flash 2, ROG CPU-Z, ROG Mem TweakIt Utility, DAEMON Tools Pro Standard, ASUS WebStorage, ASUS AI Suite III, ROG RAMDisk
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
