Asus Maximus V Gene S1155 Intel Z77 DDR3 mATX
Standard Due date unavailable
The ROG Maximus V GENE features the new Intel Z77 express chipset and comes with SupremeFX® III audio and network traffic management via Intel® Ethernet and ASUS GameFirst technology, affording smoother and more immersive gameplay. Containing display port and HDMI, the Maximus V GENE also includes Smart DIGI+ power control and the world's first Dual Intelligent Processors from ASUS consisting of two dedicated onboard chips, the TPU and EPU. This also consists of multiple digital voltage controllers that allow for ultra-precise tuning of CPU, iGPU and DRAM power delivery while working with the TPU to ramp up performance to full potential for the ultimate user experience.
The new architecture creates a cooler and quieter desktop carefully designed in accordance with next generation Intel® VRD 12.5 power standards to offer consumers the very latest in innovation and readiness. Fan Auto Tuning Mode scans fans individually to detect their thermal properties through automatic speed sensing. Custom fan speeds can be adjusted automatically or manually with a single mouse click, achieving an optimal balance of cooling and low noise. Extreme Engine Digi+ combines analogue and digital elements with an adjustable CPU PWN frequency to efficiently dissipate heat and achieve a better electric conduction; keeping the overall motherboard reliable. Fan Xpert 2 also includes an RPM Fixed Mode for users who wish to reduce noise levels to near 0dB, with highly specific fan speed controls that react to actual system loads for more accurate response.
Furthermore the Maximus V GENE includes support for both NVIDIA SLI and AMD CrossFireX which offer the ultimate in flexibility for 3D graphics and Intel® Smart Response Technology, Intel® Smart Connect Technology, and Intel® Rapid Start Technology, while also natively supporting PCI Express 3.0.
Asus Exclusive Innovations
  • 100% Japan-made Solid
  • ASUS Anti-Surge Protection;
  • DIGI+ Power Control
  • AI Suite II
  • Dual Intelligent Processors 3 - with New DIGI+ Power Control include three digital voltage controllers, allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control
  • Quad GPU AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
  • LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
Spec details
  • CPU LGA1155 socket for Intel® 3rd/2nd Generation Core™ i7/ i5/ i3/ Pentium / Celeron Processors Supports 22/32nm CPU Supports Intel Turbo Boost Technology 2.0
    • The Intel Turbo Boost Technology 2.0 support depends on the CPU types. ** Refer to for Intel CPU support list
  • Chipset Intel Z77 Express Chipset
  • Memory Dual channel memory architecture 4 x DIMM, max. 32GB, DDR3 2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz, non-ECC, un-buffered memory Supports Intel® Extreme Memory Profile (XMP)
    • Hyper DIMM support is subject to the physical characteristics of individual CPUs. ** Please refer to Memory QVL (Qualified Vendors List) for details.
  • Expansion Slots 2 x PCI Express 3.0/2.0 x16 slots [red] (Single at x16 or dual at x8/x8 mode)* 1 x PCI Express 2.0 x4 slot [black] 1 x mini-PCI Express 2.0 x1 slot on mPCIe Combo expansion card
    • PCIe3.0 speed is supported by Intel 3rd genernation Core™ Processors.
  • VGA Integrated Intel HD Graphics Processor
    • Multi-VGA output support: DisplayPort/HDMI port Supports DisplayPort 1.1a with max. resolution 2560 x 1600@60Hz Supports HDMI 1.4a with max. resolution 1920 x 1200@60Hz Supports Intel InTru 3D/Quick Sync Video/Clear Video HD Technology/Insider
  • Multi-GPU Support NVIDIA SLI™ / AMD CrossFireX Technology Supports LucidLogix Virtu MVP Technology*
    • LucidLogix Virtu MVP supports Windows 7 operating systems.
  • Storage Intel Z77 Express Chipset: 2 x SATA 6Gb/s ports [red] 2 x SATA 3Gb/s ports [black] 1 x eSATA 3Gb/s port 1 x mSATA 3Gb/s slot on mPCIe Combo expansion card Intel Rapid Storage Technology supports RAID 0, 1, 5 and 10 Supports Intel Smart Response Technology, Intel Rapid Start Technology, Intel Smart Connect Technology* ASMedia SATA 6Gb/s controller: 2 x SATA 6Gb/s ports [red]*
    • Supports on Intel Core™ processor family with Windows® 7 operating systems. * These SATA ports are for data hard drives only.
  • LAN Intel Gigabit LAN Controller x 1
  • Audio SupremeFX III, built-in 8-Channel High Definition Audio CODEC SupremeFX Shielding™ Technology 1500 uF Audio Power Capacitor Gold-plated jacks
    • Output Signal-to-Noise Ratio (A-Weighted): 110 dB
    • Output THD+N at 1kHz: 95 dB Audio Feature:
      • X-F® Xtreme Fidelity
      • EAX Advanced™ HD 5.0
      • THX TruStudio PRO
      • Creative ALchemy
    • Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
    • Blu-ray audio layer Content Protection
    • Optical S/PDIF out port at back panel
  • USB Intel Z77 Express Chipset: 4 x USB 3.0 ports; 2 ports at back panel [blue], 2 ports at mid-board [red]* 8 x USB 2.0 ports; 4 ports at back panel, 1 for ROG Connect [white]; 4 ports at mid-board ASMedia USB 3.0 controller: 2 x USB 3.0 ports; 2 ports at back panel [blue] *UASP standard only supports Windows 8.
  • ROG Exclusive Features mPCIe Combo (mPCIe/mSATA combo card) ROG Connect
    • RC Diagram
    • RC Remote
    • RC Poster
    • GPU TweakIt ROG Extreme Engine Digi+ II
    • 8 phase CPU power
    • 4 phase iGPU power
    • 2 phase DRAM power UEFI BIOS features :
    • ROG BIOS Print
    • GPU.DIMM Post CPU Level Up GameFirst ProbeIt iROG Extreme Tweaker USB BIOS Flashback Loadline Calibration ROG O.C. Profile
  • Special Features ASUS EPU Engine ASUS Exclusive Features
    • AI Suite II
    • TurboV EVO
    • USB 3.0 Boost
    • Fan Xpert 2
    • AI Charger+
    • Disk Unlocker ASUS EZ DIY
    • ASUS CrashFree BIOS 3
    • ASUS EZ Flash 2
    • ASUS C.P.R.(CPU Parameter Recall) ASUS Q-Design
    • ASUS Q-Connector
    • ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    • ASUS Q-Slot
  • Back I/O Ports 1 x Clear CMOS button 1 x ROG Connect On/Off switch 4 x USB 2.0 (1 port can be switched to ROG Connect) 1 x eSATA 3Gb/s 4 x USB 3.0 [blue] 1 x Optical S/PDIF out 1 x HDMI port 1 x DisplayPort 1 x LAN (RJ45) port 6 x Audio jacks
  • Internal I/O Ports 1 x USB 3.0 connector supports additional 2 USB 3.0 ports 2 x USB 2.0 connectors support additional 4 USB 2.0 ports 4 x SATA 6Gb/s connectors 2 x SATA 3Gb/s connectors 2 x CPU Fan connectors 3 x Chassis Fan connectors 1 x 24-pin EATX Power connector 1 x 8-pin EATX 12V Power connector 8 x ProbeIt Measurement Points 1 x Power-on button 1 x Reset button 1 x Go Button 1 x S/PDIF out header 1 x Front panel audio connector (AAFP) 1 x System panel connector 1 x mPCIe Combo header
  • Accessory User's manual I/O Shield 2 x 2-in-1 SATA 6Gb/s signal cables 1 x 2-in-1 SATA 3Gb/s signal cables 1 x SLI bridge 1
ASUS MAXIMUS V GENE - Republic of Gamers - motherboard - micro ATX - LGA1155 Socket - Z77
Motherboard - micro ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600, 3 x SATA-300 (RAID), 1 x eSATA-300
USB / FireWire Ports
4 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Supported RAM Integrity Check
Registered or Buffered
Audio Codec
SupremeFX III
High Definition Audio, THX TruStudio Pro, Creative ALchemy, EAX ADVANCED HD 5.0, X-Fi Xtreme Fidelity
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x4 , 1 x PCIe Mini Card
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 2 x 7pin SATA, 1 x mSATA, 1 x 7pin eSATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 4 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
2 x USB 3.0 , 4 x USB 2.0 , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, NVIDIA SLI Technology Support, ASUS Q-Design, GameFirst, ROG Connect, ASUS TurboV EVO, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS Extreme Tweaker, ASUS Loadline Calibration, Intel Extreme Memory Profile (XMP) support, ASUS iROG, Intel Turbo Boost Technology 2.0, GPU.DIMM Post, ROG BIOS Print, ROG CPU-Z, USB 3.0 Boost, ASUS 8 Phase CPU Power Design, ASUS Extreme Engine Digi+ II, SupremeFX Shielding technology, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, Intel InTru 3D Technology
ROG connect cable, mPCIe Combo expansion card
6 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, Kaspersky Anti-Virus, ASUS AI Suite II, ASUS AI Charger+, ROG CPU-Z, Creative Sound Blaster X-Fi 2 utility, DAEMON Tools Pro Standard, ASUS WebStorage
Plug and Play, ACPI 2.0a
24.4 cm
24.4 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great board
Reviewed by elbag on 07/06/2012
Love this board it has a real nice look to it being rog and the red LED line behind the board running along the sound chip is a nice touch. flash bios etc very handy and all in all a good product.
Scroll to top
