BT.com
Wishlist
Asus M5A99FX PRO R2.0 AM3+ AMD 990FX DDR3 ATX
Asus M5A99FX PRO R2.0 AM3+ AMD...
£139.42
£139.42
Add to wishlist
Delivery
Standard Due date unavailable
M5A99FX PRO R2.0: CPU and DRAM Digital Power Design for a 100% Performance Boost on AMD 990FX Platform
  • Dual Intelligent Processors 3 with New DIGI+ Power Control - Full Hardware Control. Total Performance Tuning.
  • Remote GO! - One-stop PC Remote Control and Home Entertainment
  • USB 3.0 Boost - Faster USB 3.0 Transmission with UASP
  • Network iControl - Real-time Network Bandwidth Control
  • DirectKey - A Dedicated Button to Access the BIOS Directly
  • USB BIOS Flashback - Easy, Worry-free USB BIOS Flashback with Hardware-based Design
  • UEFI BIOS - Flexible & Easy BIOS Interface
The world's first dual intelligent processors from ASUS pioneered twin onboard chips - TPU (TurboV Processing Unit) and EPU (Energy Processing Unit). Third generation Dual Intelligent Processors with DIGI+ power control provides a total CPU, memory and SMART DIGI+ Key profile tuning digital power solution, which includes two digital voltage controllers allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control - a first on the AMD platform. It's upgraded with one-click extreme performance optimization with the user-friendly AI Suite II utility. This evolution of innovative and industry-leading ASUS technology provides super-accurate voltage tuning for better efficiency, stability and performance.
The DIGI+ power control design with two digital voltage controllers upgrades motherboard power delivery to an overall solution on AMD AM3+ motherboards, including all DRAM controllers that offers ultra-precise memory tuning in addition to ultra-precise CPU voltage control. This evolution of innovative, industry-leading ASUS technology provides the best in class control for better efficiency, stability and performance.
ASUS facilitates strategic USB 3.0 accessibility for both the front and rear panel - 4 USB 3.0 ports in total. Experience the latest plug & play connectivity at speeds up to 10 times faster than USB 2.0. This motherboard affords greater convenience to high speed connectivity.
ASUS M5A99FX PRO R2.0 - motherboard - ATX - Socket AM3+ - AMD 990FX
Motherboard - ATX
Chipset Type
AMD 990FX / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Athlon II, Phenom II, FX (supports CPUs with up to 8 cores, Maximum TDP 220 Watt)
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
Storage Ports
5 x SATA-600, 2 x SATA-600, 1 x eSATA-300
USB / FireWire Ports
2 x USB 3.0 + 8 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Max Bus Speed
2600 MHz
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC892
DTS Connect, High Definition Audio, DTS UltraPC II
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 2 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
AMD SB950: SATA-600 -connectors: 5 x 7pin SATA, 1 x 7pin eSATA - 6 devices , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 8 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
2 x USB 3.0 , 8 x USB 2.0 , 1 x serial , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS MyLogo3, ASUS O.C. Profile, ACPI 2.0a support, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ASUS Q-Connector, ASUS Noise Filter, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Precision Tweaker 2, ASUS Fan Xpert, NVIDIA Quad SLI Technology Support, ASUS TurboV, ASUS 6+2 Phase Power Design, ASUS TPU (TurboV Processing Unit), USB 3.0 Boost, Dual Intelligent Processors 3, Fanless Design Heat-pipe, AMD Quad CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Network iControl, ASUS SMART DIGI+, ASUS Remote GO!, DirectKey
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+, ASUS CPU-Z
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
