Click to visit BT.com
BT.com
Wishlist
Asus M5A97 EVO R2.0 AM3+ AMD 970 + SB950 DDR3 ATX
Quicklinx: 87SXWS00
Mfr#: M5A97 EVO R2.0
Essential accessories
M5A97 EVO R2.0: CPU and DRAM Digital Power Design for a 100% Performance Boost on AMD 970 with Windows 8 Support
  • Dual Intelligent Processors 3 with New DIGI+ Power Control - Full Hardware Control. Total Performance Tuning.
  • Remote GO! - One-stop PC Remote Control and Home Entertainment
  • USB 3.0 Boost - Faster USB 3.0 Transmission with UASP
  • Network iControl - Real-time Network Bandwidth Control
  • DirectKey - A Dedicated Button to Access the BIOS Directly
  • USB BIOS Flashback - Easy, Worry-free USB BIOS Flashback with Hardware-based Design
  • UEFI BIOS - Flexible & Easy BIOS Interface
  • Windows 8 Ready - Assured Compatibility
The dual intelligent processors from ASUS pioneered the use of two onboard chips - EPU (Energy Processing Unit) and TPU (TurboV Processing Unit). The next generation of dual intelligent processors 2 with DIGI+ VRM provides precise Vcore PWM, integrated graphics voltages and frequency module adjustments with minimal power loss through BIOS tuning and an exclusive user interface to increase the board's overclocking range while performance reaches its full potential. ASUS DIGI+ VRM digital power design empowers users with superior flexibility and perfect precision to ensure optimized performance, extreme system stability and greater power efficiency.
VRM, or voltage regulator modules, is considered among the most essential motherboard design components. They supply the voltage demanded by the CPU, and a good VRM must intelligently detect actual CPU power draw to provide precise power accordingly. ASUS DIGI+ VRM features a digital programmable microprocessor onboard to perfectly match digital power signal (SVID) requests from the CPU, eliminating digital-to-analog conversion lag. The precise power delivery minimizes power transfer loss to provide highest power efficiency, greater performance, and rock solid stability with the most flexible power adjustment than traditional analog power design.
AMD® Socket AM3+ for AMD® FX Series CPU up to 8-core: AMD® FX™-Series/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors (socket AM3+/AM3)
M5A97 EVO R2.0 supports AMD® AM3+/AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 1866 memory support and accelerates data transfer rate up to 4800MT/s via HyperTransport™ 3.0 based system bus. This motherboard also supports AMD® CPUs in the new 32nm manufacturing process.
AMD® 970 Chipset
AMD® 970 Chipset is designed to support up to 4800MT HyperTransport™ 3.0 (HT 3.0) interface speed and PCI Express™ 2.0 x16 graphics. It is optimized with AMD®'s latest AM3+ and multi-core CPUs to provide excellent system performance and overclocking capabilities.
Quad-GPU CrossFireX Support. Flexible Multi-GPU Solutions, Your Weapon of Choice!
AMD's CrossFireX™ boosts image quality along with rendering speed, eliminating the need to scale down screen resolution to get high quality images. CrossFireX™ allows higher antialiasing, anisotropic filtering, shading and texture settings. Adjust your display configurations, experiment with the 3D settings, and check the effects with a real-time 3D-rendered previews within AMD Vision™ Engine Control Center.
Windows 8 Ready
With hardware driver compatibility tested and assured, ASUS provides a complete solution for Windows 8 support. Starting now, users can experience the next generation operating system on ASUS hardware, and can rest assured that they can easily upgrade once the final driver versions are released without any compatibility issues!
ASUS M5A97 EVO - 2.0 - motherboard - ATX - Socket AM3+ - AMD 970
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Athlon X2, Sempron X2, Phenom II X4, Phenom II X6, FX ( supports CPUs with up to 8 cores, Maximum TDP 140 Watt )
Data Bus Transfer Rate
4.8 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x eSATA-600
USB / FireWire Ports
2 x USB 3.0 + 1 x FireWire + 8 x USB 2.0 + ( 1 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
4.8 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC892
DTS Connect, High Definition Audio, DTS UltraPC II
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
AMD SB950 : SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin external SATA - 2 devices
1 x PS/2 keyboard / mouse , 1 x FireWire - 4 pin FireWire , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 8 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x serial - header , 1 x SPDIF out - header , 1 x audio - header , 2 x USB 3.0 , 1 x FireWire - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, USB BIOS Flashback, ASUS EFI BIOS, UEFI BIOS, SMBIOS 2.7 support
Manual Settings
CPU frequency, processor core voltage, memory voltage, memory bus frequency
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ASUS Q-Connector, ASUS Noise Filter, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Precision Tweaker 2, ASUS Fan Xpert, ASUS TurboV, ASUS 6+2 Phase Power Design, Solid Capacitor for CPU power, Loss-less content protection technology, Fanless Design Heatsink, USB 3.0 Boost, Dual Intelligent Processors 3, AMD Quad CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Network iControl, ASUS SMART DIGI+, ASUS Remote GO!, DirectKey
I/O back plate
3 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Suite II, ASUS AI Charger+
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
30.5 cm
24.4 cm
3 years warranty
Service & Support Details
Limited warranty - 3 years
