Click to visit BT.com
BT.com
Wishlist
ASUS M5A78L-M/USB3 - m-ATX Socket AM3+ AMD 760G USB3.0 - onboard graphics, HD Audio
5.0*
Quicklinx: 7MMBWS00
Mfr#: M5A78L-M/USB3
Processor Socket: Socket AM3+
Chipset: AMD 760G
Graphics: Graphics adapter
Form Factor: Micro ATX
Memory Support: DDR3 SDRAM
Standard delivery Delivered within 3-5 working days
16 in stock
£62.68
Essential accessories
The ASUS EPU (Energy Processing Unit) provides total system power management by detecting current PC loadings and intelligently moderating power usage for critical PC components in real-time - helping save power and money!
Experience ultra-fast data transfer at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10 times faster and is also backward compatible with USB 2.0 components.
With its user-friendly interface, ASUS AI Suite II consolidates all the exclusive ASUS features into one simple to use software package. It allows users to supervise Overclocking, energy management, fan speed control, voltage and sensor readings. This all-in-one software offers diverse and ease to use functions, with no need to switch back and forth between different utilities.
ASUS M5A78L-M/USB3 - motherboard - micro ATX - Socket AM3+ - AMD 760G
Motherboard - micro ATX
Chipset Type
AMD 760G / AMD SB710
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6, FX ( Maximum TDP 140 Watt )
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
16 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC, ECC , unbuffered
Storage Ports
6 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 6 x USB 2.0 via headers )
Graphics
ATI Radeon HD 3000
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Chipset Type
Max Bus Speed
2600 MHz
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz
Speed
PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
ATI Radeon HD 3000
Memory Allocation Technology
Shared Video Memory (UMA)
Audio
Audio Codec
VIA VT1708S
High Definition Audio
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe x16 , 2 x PCIe x1 , 1 x PCI
Storage Interfaces
AMD SB710 : SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
1 x serial , 1 x SPDIF out , 1 x parallel , 1 x audio
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support
Hardware Features
ASUS Q-Fan, C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, ASUS Anti-Surge Protection, ASUS Turbo Key, CrashFree BIOS 3, ASUS EPU (Energy Processing Unit), Core Unlocker, AMD Hybrid CrossFireX technology support
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS Live Update, ASUS PC Probe 2, ASUS AI Suite II, ASUS AI Charger
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
20.3 cm
Limited warranty - 3 years
ASUS M5A78L-M/USB3 - m-ATX Socket AM3+ AMD 760G USB3.0 - onboard graphics, HD Audio Bundle deal on ASUS M5A78L-M/USB3 - m-ATX Socket AM3+ AMD 760G USB3.0 - onboard graphics, HD Audio
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£80.93
saving £8.26
Including:
£63.20
saving £1.80
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£65.49
saving £1.39
Customer reviews
Write a review for the ASUS M5A78L-M/USB3 - m-ATX Socket AM3+ AMD 760G USB3.0 - onboard graphics, HD Audio here!
Great Board
Reviewed by Andrew. Review Posted 31/12/2011
I used this board for my first build. The board has plenty of USB2.0 slots as USB3.0 is backwards compatible. The board has plenty of BIOS options for moderate overclocking. It is great for the price. I have practically no concerns with this board. Overall, a great board with plenty of features for the price.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Very simple to setup
Reviewed by Paul. Review Posted 06/08/2013
Very easy to setup and worked straight out of the box with my AMD FX6350 Black edition processor. Overclocked processor to 4200 Mhz via the bios and its solid as a rock touch wood. Will push it a fraction more to see where I can get to. Great board for price.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Chipset: AMD 760G
Max Processors: 1
Brand: Asus
Price Range Inc VAT: 50 - 100
