BT.com
Wishlist
Asus M5A78L-M LX3 AM3+ AMD 760G DDR3 uATX
Asus M5A78L-M LX3 AM3+ AMD 760G...
£44.01
12 in stock
£44.01
Add to wishlist
Delivery
Standard 3-5 working days
M5A78L-M LX3: The most cost-effective solution for the AM3+ platform combined with ASUS EPU
  • AM3+ CPU Support Ready
  • Core Unlocker- Unlock true Core performance intelligently
  • Anti-Surge- Full-time Power Guardian-Make System Free From Risk
  • ASUS EPU- System Level Energy Saving
  • Low EMI- protect you - 50% less radiation
ASUS M5A78L-M LX3 - motherboard - micro ATX - Socket AM3+ - AMD 760G
Motherboard - micro ATX
Chipset Type
AMD 760G / AMD SB710
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6, FX (Maximum TDP 95 Watt)
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, ECC, unbuffered
Storage Ports
4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + (4 x USB 2.0 via headers)
Graphics
ATI Radeon HD 3000
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Max Bus Speed
2600 MHz
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
ATI Radeon HD 3000
Memory Allocation Technology
Shared Video Memory (UMA)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
AMD SB710: SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x serial , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
4 x USB 2.0 , 1 x audio
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.7 support
Hardware Features
C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, ASUS Anti-Surge Protection, ESD Guards, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS EPU-4 Engine, Core Unlocker, AMD Hybrid CrossFireX technology support
Software Included
Drivers & Utilities, ASUS PC Probe 2, ASUS AI Charger, ASUS Update
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
18.8 cm
£44.01
Save on this ideal PC Build kit!
Save £8.40
£63.23
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* No video error on this board from two different suppliers.
Reviewed by Anonymous on 06/12/2014
Specs looked great 'cos I wanted ECC memory support and on-board VGA but I've had two of these motherboards from two separate suppliers and both have had NO video output from the VGA or HDMI ports. Both have had to be sent back. A real pain.
Scroll to top
