BT.com
Wishlist
Asus M5A78L-M LX AM3+ AMD 760G + SB710 DDR3 ATX
Delivery
Standard Due date unavailable
M5A78L-M LX: Intelligently unlock multi-core performance with ASUS Core Unlocker!
  • ASUS EPU - System Level Energy Saving
  • Anti - surge - Full-time Power Guardian-Make System Free From Risk
  • Turbo key - Touch-n-Boost!
  • Core Unlocker - Unleash True Core Performance Intelligently
This motherboard supports AMD AM3+ multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 memory support and accelerates data transfer rate up to 5200 MT/s via HyperTransport 3.0 based system bus. This motherboard also supports AMD CPUs in the 32 nm manufacturing process.
AMD® FX™ /Phenom™II /Athlon™II /Sempron™ 100 Series Processors (Socket AM3+)
This motherboard supports AMD® AM3+ multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport™ 3.0 based system bus. This motherboard also supports AMD® CPUs in the new 32nm manufacturing process.
Core Unlocker: Unleash True Core Performance Intelligently
ASUS Core Unlocker simplifies the activation of a latent AMD® CPU--with just pressing a key. Enjoy an instant performance boost by simply unlocking the extra cores, without performing complicated BIOS changes.
EPU-4 Engine: System Level Energy Saving
The new ASUS EPU - the world´s first power saving engine, has been upgraded to a new 4-engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real-time. The EPU automatically provides the most appropriate power usage for the CPU, VGA card, hard drives and CPU cooler fan - helping save power and money.
Turbo Key
ASUS Turbo Key allows the user to turn the PC power button into a physical overclocking button. After the easy setup, Turbo Key can boost performances without interrupting ongoing work or games - with just one touch!!
ESD
Protect Your Computer with ESD Guards. Electrostatic discharge (ESD) conditions can happen while plugging or unplugging any USB peripherals-causing damage to the computer. ASUS ESD Guards clamp the ESD voltage and shunt the majority of the ESD current away for a more reliable computing environment.
ASUS Anti-Surge Protection
Anti-Surge Protection Design detects overvoltage conditions and prevents voltage surges from spreading in real time. It also actively cuts off the overvoltage supply to protect the system. 1. Real-time over voltage detection. 2. Active protection against potential damage to your motherboards and systems.
8-channel high definition audio
Enjoy high-end sound system on your PC! The onboard 8-channel HD audio (High Definition Audio, previously codenamed Azalia) CODEC enables high-quality 192KHz/24-bit audio output, jack-sensing feature, retasking functions and multi-streaming technology that simultaneously sends different audio streams to different destinations. You can now talk to your partners on the headphone while playing a multi-channel network games. All of these are done on one computer. * Use the chassis with HD audio module in the front panel to support 8-channel audio output.
CrashFree BIOS 3
Simply restore corrupted BIOS data from USB flash disk. The ASUS CrashFree BIOS 3 allows users to restore corrupted BIOS data from a USB flash disk containing the BIOS file. This utility saves users the cost and hassle of buying a replacement BIOS chip.
EZ-Flash 2
Simply update BIOS from a USB flash disk before entering the OS. EZ Flash 2 is a user-friendly BIOS update utility. Simply launch this tool and update BIOS from a USB flash disk before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or using an OS-based flash utility.
C.P.R.(CPU Parameter Recall)
The BIOS C.P.R. feature automatically restores the CPU default settings when the system hangs due to overclocking failure. C.P.R. eliminates the need to open the system chassis and clear the RTC data. Simply shut down and reboot the system, and the BIOS automatically restores the CPU parameters to their default settings.
ErP ready
The motherboard is European Union´s Energy-related Products (ErP) ready, and ErP requires products to meet certain energy efficiency requirements in regards to energy consumptions. This is in line with ASUS vision of creating environment-friendly and energy-efficient products through product design and innovation to reduce carbon footprint of the product and thus mitigate environmental impacts.
Q-FAN
ASUS Q-Fan technology intelligently adjusts fan speeds according to system loading to ensure quiet, cool and efficient operation.
ASUS M5A78L-M LX - motherboard - micro ATX - Socket AM3+ - AMD 760G
Motherboard - micro ATX
Chipset Type
AMD 760G / AMD SB710
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6, FX ( Maximum TDP 95 Watt )
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
8 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC, ECC , unbuffered
Storage Ports
6 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + ( 6 x USB 2.0 via headers )
Graphics
ATI Radeon HD 3000
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Chipset Type
Max Bus Speed
2600 MHz
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
8 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz
Speed
PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
ATI Radeon HD 3000
Memory Allocation Technology
Shared Video Memory (UMA)
1 GB
Audio
Audio Codec
Realtek ALC887
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe x16 , 2 x PCIe x1 , 1 x PCI
Storage Interfaces
AMD SB710: SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x VGA , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x parallel , 1 x serial , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x SPDIF out , 1 x audio
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support
Hardware Features
ASUS Q-Fan, C.P.R. (CPU Parameter Recall), ASUS Anti-Surge Protection, ASUS Turbo Key, ESD Guards, CrashFree BIOS 3, ASUS EPU-4 Engine, Core Unlocker, AMD Hybrid CrossFireX technology support
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS Live Update, ASUS PC Probe 2, ASUS AI Charger
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
20.3 cm
Limited warranty - 3 years
Scroll to top
