BT.com
Wishlist
Asus M4N68T-M LE V2, NForce 7025/630a, AM3, 2DDR3, Onboard DSUB, PCI-Ex16, Raid, 8 CHHD Sound, mATX
Delivery
Standard Due date unavailable
This motherboard supports AMD Socket AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 1333 memory support and accelerates data transfer rate up to 2000MT/s via HyperTransport 1.0 based system bus. This motherboard also supports AMD CPUs in the 45nm manufacturing process.
This motherboard supports DDR3 1800 (O.C.) that provides faster data transfer rate and more bandwidth to increase memory computing efficiency, enhancing system performance in 3D graphics and other memory demanding applications. M4N68T-M LE V2 supports AMD Cool 'n' Quiet! technology which monitors system operation and automatically adjusts CPU voltage and frequency for a cool and quiet environment.
Features ASUS Core Unlocker which simplifies the activation of a latent AMD® CPU--with just a simply switch. Enjoy an instant performance boost by simply unlocking the extra cores, without performing complicated BIOS changes.
ASUS M4N68T-M LE V2 - motherboard - micro ATX - Socket AM3 - GeForce 7025
Motherboard - micro ATX
Chipset Type
NVIDIA GeForce 7025 / nForce 630a
Processor Socket
1 x Socket AM3
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, ECC, unbuffered
Storage Ports
4 x SATA-300 (RAID), 1 x ATA-133
USB / FireWire Ports
4 x USB 2.0 + (6 x USB 2.0 via headers)
Graphics
NVIDIA GeForce 7025
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
3 years warranty
Chipset Type
Processor Socket
Socket AM3
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz
Speed
PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
NVIDIA GeForce 7025
Audio
Audio Codec
VIA VT1708S
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe x16 , 1 x PCIe x1 , 2 x PCI
Storage Interfaces
ATA-133 -connectors: 1 x 40pin IDC - 2 devices , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x parallel , 1 x serial , 1 x VGA , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support
Hardware Features
ASUS Q-Fan, C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, ASUS Anti-Surge Protection, ASUS Turbo Key, CrashFree BIOS 3, ASUS AI NET2, ASUS Stepless Frequency Selection (SFS), ASUS EPU-4 Engine, Core Unlocker
2 x Serial ATA cable , 1 x IDE cable
Software Included
Drivers & Utilities, ASUS Live Update, ASUS PC Probe 2
Plug and Play, RoHS, ACPI 2.0a
24.4 cm
20.8 cm
Limited warranty - 3 years
Scroll to top
