BT.com
Wishlist
Asus Intel Ultimate Bundle (Includes Maximus V Formula, Core i7-3770K & 16GB Corsair Vengeance LP)
Delivery
Standard Due date unavailable
Exclusive Self-Build Special Bundle
High Performance - Without The High Price Tag!
Take the fear out of Self-Build with this tested Intel Ultimate Bundle! We test it so you don't have to! Motherboard, CPU & Memory - Boxed & Ready To Rock!
Asus Intel Maximus V Formula Motherboard: Mixes air and water cooling with superior graphics power
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
  • LGA1155 socket for Intel® 3rd/2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
  • Intel® Z77 Express Chipset
  • Fusion Thermal
  • SupremeFX IV
  • GameFirst II/ Intel Gb LAN
  • mPCIe Combo + dual-band Wi-Fi/Bluetooth 4.0
This motherboard supports LGA1155 socket for 3rd generation Intel® Core™ processor-based platform and 2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors in the LGA1155 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. LGA1155 socket for 3rd generation Intel® Core™ processor-based platform and 2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processorsare among the most powerful and energy efficient CPUs in the world
PCI Express® 3.0 (PCIe 3.0) is the latest PCI Express bus standard with improved encoding schemes that provide twice the performance of current PCIe 2.0. Total bandwidth for a x16 link reaches a maximum of 32GB/s, double the 16GB/s of PCIe 2.0 (in x16 mode). As such, PCIe 3.0 provides users unprecedented data speeds, combined with the convenience and seamless transition offered by complete backward compatibility with PCIe 1.0 and PCIe 2.0 devices. PCIe 3.0 will become a must-have feature for users who wish to improve and optimize graphic performance, as well as have the latest technology available to them.
The Intel® Z77 Express Chipset is a single-chipset design to support LGA1155 socket for 3rd generation Intel® Core™ processor-based platform and 2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z77 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel® Z77 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
Intel Core i7-3770K S1155 3.5GHz 8MB Processor (BX80637I73770K)
With faster, intelligent, multi-core technology that applies processing power where it's needed most, Intel Core i7 processors deliver an incredible breakthrough in PC performance. They are the best desktop processors on the planet.
You'll multitask applications faster and unleash incredible digital media creation. And you'll experience maximum performance for everything you do.
Corsair 16GB (2 x 8GB) Vengeance Low Profile DDR3 1600MHz DIMM 240-pin CL10 (CML16GX3M2A1600C10B)
Vengeance Low Profile heat spreaders have a reduced height of 1.03" (26.25mm). They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where standard Vengeance memory might not fit.
Each Vengeance memory module is built from DRAM ICs specially selected for performance potential, to allow you to explore the limits of system overclocking.
If you're new to overclocking, full support for Intel Extreme Memory Profile (Intel XMP) makes it easy. Add Vengeance to your XMP-compatible system and it can automatically select the maximum possible overclocking performance, quickly and easily.
ASUS MAXIMUS V FORMULA - Republic of Gamers - motherboard - extended ATX - LGA1155 Socket - Z77
Motherboard - extended ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600 (RAID), 4 x SATA-600, 3 x SATA-300 (RAID), 1 x eSATA-300
USB / FireWire Ports
4 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
802.11a/b/g/n, Bluetooth, Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
SupremeFX IV
DTS Connect, High Definition Audio, DTS UltraPC II
LAN
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 3.0 x16 , 1 x PCIe 2.0 x4 , 3 x PCIe 2.0 x1 , 1 x PCI Express 2.0 Mini Card
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 2 x 7pin SATA, 1 x mSATA, 1 x 7pin eSATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
RAID Features
Intel Smart Response Technology
1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x TOSLINK
Internal Interfaces
2 x USB 3.0 , 4 x USB 2.0 , 1 x SPDIF out , 1 x audio
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
EZ Plug, C.P.R. (CPU Parameter Recall), jack retasking, NVIDIA SLI Technology Support, ASUS Q-Design, ROG Connect, ASUS TurboV EVO, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Extreme Tweaker, ASUS Loadline Calibration, Intel Extreme Memory Profile (XMP) support, ASUS iROG, Intel Turbo Boost Technology 2.0, GPU.DIMM Post, Intel Clear Video HD Technology, Intel Smart Response Technology, ROG BIOS Print, USB 3.0 Boost, ASUS ROG Extreme OC, ASUS Extreme Engine Digi+ II, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS Fan Xpert 2, ASUS USB Charger+, ASUS Wi-Fi GO!, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, Onboard mSATA Connector, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, GameFirst II, ROG Fusion Thermo
I/O back plate, Bluetooth / Wi-Fi module, ROG connect cable, 2 x Wi-Fi Ring Moving Antennas, mPCIe Combo expansion card
6 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, Kaspersky Anti-Virus, ASUS AI Suite II, ASUS AI Charger+, ROG CPU-Z, DAEMON Tools Pro Standard, ASUS WebStorage
Plug and Play, ACPI 2.0a
30.5 cm
25.7 cm
Limited warranty - 3 years
Scroll to top
