BT.com
Wishlist
Asus Intel Premium Bundle (Inc P8H61-MX/USB3 Motherboard, Intel Core i3-2100 & 4GB DDR3 Memory)
Free delivery
Delivery
Standard Due date unavailable
Exclusive Self-Build Special Bundle
Perfect Premium PC on the H61 Platform!
Take the fear out of Self-Build with this tested Intel Premium Bundle! We test it so you don't have to! Motherboard, CPU & Memory - Boxed & Ready To Rock!
Asus P8H61-MX/USB3 Intel Motherboard
  • Better graphics with iGPU Boost on Intel H61
  • GPU Boost - Instant iGPU Level Up!
  • UEFI BIOS - EZ Mode - Flexible & Easy BIOS Interface
  • AI Suite II - One-stop Access to Innovative ASUS Features
  • EPU - System Level Energy Saving
This motherboard supports the Intel Ivy Bridge processor in the LGA1155 package, with memory and PCI Express controllers integrated to support 2-channel DDR3 memory and 16 PCI Express 3.0 lanes. This provides great graphics performance.
The motherboard supports DDR3 memory that features high data transfer rates to meet the higher bandwidth requirements of the 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance.
The motherboard is Energy-related Products (ErP) ready, and ErP requires products to meet certain energy efficiency requirements in regards to energy consumptions. This is in line with ASUS vision of creating environment-friendly and energy-efficient products through product design and excellent to reduce carbon footprint of the product and thus mitigate environmental impacts.
Intel Core i3-2100 3.10GHz 3MB Processor (BX80623I32100)
The Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. This processor comes equipped with Intel HD graphics, an advanced video engine that delivers smooth, high-quality HD video playback, and advanced 3D capabilities, providing an ideal graphics solution for everyday computing.
A smart choice for home and office, the Intel Core i3 processor also features Intel Hyper-Threading technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Do not let too many open applications slow you and your PC down. Get smart performance now.
4GB (1x4GB) Patriot Signature DDR3 1333MHz CL9 Memory (PSD34G13332)
Designed with reliability, performance and value in mind, Patriot Signature DDR3 PC3-10600 (1333MHz) is the perfect memory upgrade solution for desktop and workstation systems. Patriot ensures that every memory module meets and exceeds industry standards.
  • PC3-10600 (1333MHz) Data Rate
  • 240-Pin Dual in-line memory module
  • Non-ECC Unbuffered
  • 2 Rank Doouble-sided module
  • 7.8US Refresh Interval (8192 CYCLES/64MS)
  • 1.5V Power Requirement
  • Auto and self refresh capability
  • PCB height: 1181(mil)
  • Serial Presence-Detect (SPD)
  • 100% Tested
  • RoHS Compliant
ASUS P8H61-MX USB3 - motherboard - micro ATX - LGA1155 Socket - H61
Motherboard - micro ATX
Chipset Type
Intel H61 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
4 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H61 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
2200 MHz, 2000 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
VIA VT1708S
High Definition Audio
LAN
Network Controller
Realtek RTL8111F-VB-CG
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 ( 3rd generation Intel Core processor must be installed ) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices
1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-out (rear)/line-in - mini-jack , 1 x audio line-out (centre/subwoofer)/microphone - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASUS Q-Fan 2, ASUS Anti-Surge Protection, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, ASUS Fan Xpert, ASUS Network iControl
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
18.3 cm
Scroll to top
