BT.com
Wishlist
Asus Intel PDC Anniversary Bundle (Includes H81M-PLUS, Intel PDC G3258, 8GB Vengeance Memory)
Perfect Performance PC on the H81 Platform!
Delivery
Standard Due date unavailable
Exclusive Self-Build Special Bundle
Perfect Performance PC on the H81 Platform - with Intel 4th Pentium K Anniversary Dual Core Processor!
Take the fear out of Self-Build with this tested Intel Performance Bundle! We test it so you don't have to! Motherboard, CPU & Memory - Boxed & Ready To Rock!
Asus H81M-PLUS Intel Motherboard: Micro-ATX H81 features new high-endurance 5X Protection and 4 USB 3.0 support with superfast USB 3.0 Boost technology
  • ASUS 5X Protection - All-round protection provides the best quality, reliability, and durability
  • USB 3.0 Boost (UASP Support) - 170% faster transfer speeds than traditional USB 3.0
  • HDMI & DVI Outputs - High-definition Visual Enjoyment
  • New UEFI BIOS - Friendlier, easier, and more intuitive with helpful info added
  • Network iControl - Real-time network bandwidth management
ASUS 5X Protection
ASUS motherboards guard your PC with 5X Protection. We use quality components like DIGI+ VRM digital power design for precise CPU power on demand, ESD units tested to strict standards that eliminate electrostatic interference, and resettable fuses around DRAM slots to prevent overcurrent and short-circuit damage. We also use corrosion-resistant back I/O shields, all examples of ASUS providing the best possible reliability and durability.
ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol) in Windows 8. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to already fast USB 3.0 performance. ASUS software automatically accelerates data rates for compatible USB 3.0 peripherals without any user interaction.
4K Ultra HD ready
Following up on popular 1080p full HD, 4K Ultra HD is the next big thing, and you're ready for the upgrade thanks to integrated graphics that natively support up to 4096 x 2160 via HDMI or DisplayPort. That's four times the pixel count of 1080p (1920 x 1080), offering incredible visual clarity, detail, and realism.
Intel® LGA1150 4th, New 4th & 5th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors Ready
This motherboard supports Intel® 4th , New 4th and 5th Generation Core™ i7/i5/i3/Pentium®/Celeron® processors in the LGA1150 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance.
Intel® H81 Express Chipset
The Intel® H81 Express chipset is a single-chipset design that supports socket LGA1150 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It natively supports up to two USB 3.0 ports for up to ten times faster transfer rates than USB 2.0. Moreover, the Intel® H81 Express chipset also supports iGPU functionality, letting users enjoy the latest Intel integrated graphics performance.
Intel Pentium Dual Core G3258 3.20GHz 3MB S1150 Pentium K Anniversary Processor (BX80646G3258)
Enjoy a new PC with an improved Intel® Pentium® processor. Experience brilliant PC performance that lets you communicate with friends and family, enjoy entertainment, and get your work done. Get the Intel level performance you've come to expect and quality you can count on with an Intel Pentium processor.
  • Great performance at a great price
  • Perfect for your everyday tasks
  • Exceptional value
  • Classic processor from Intel--now updated
  • Intel quality and reliability
Specification
  • Lithography Process: 22 nm
  • Cores: 2
  • Threads: 2
  • Frequency: 3.20GHz
  • Integrated HD Graphics
  • Cache: 3MB shared L3
  • Memory Controller: Dual channel DDR3 1600/1866/2133/2400/2666+ MHz
  • Socket: LGA1150
  • Memory compatibility: All DDR3 1333MHz and above is compatible
  • 3yr Warranty
  • There is a stock cooler in the box but please purchase an aftermarket cooler if you wish to overclock this chip. We recommend Corsair Hydro coolers for best performance.
Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Low Profile Black Performance Desktop Memory Kit (CML8GX3M2A1600C9)
Corsair high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel platforms. These Vengeance modules are designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or other space-constrained applications that prevent the use of standard Vengeance memory. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
What's in the box
  • ASUS H81M-PLUS
  • 2 x Serial ATA cable
  • I/O back plate
  • Software
ASUS H81M-PLUS - motherboard - micro ATX - LGA1150 Socket - H81
Motherboard - micro ATX
Chipset Type
Intel H81 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600, 2 x SATA-300
USB / FireWire Ports
USB 3.0 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H81 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 3 x PCIe 2.0 x1
Storage Interfaces
SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x DVI , 1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 2 x USB 3.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, ASUS EFI BIOS, UEFI BIOS, SMBIOS 2.7 support
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, Intel Clear Video Technology, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Fanless Design Heatsink, ASUS USB 3.0 Boost technology, ASUS Network iControl, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ESD Protection, ASUS 5X PROTECTION, 4K Ultra HD ready, ASUS Enhanced DRAM Overcurrent Protection, ASUS Boot Setting, Clear CMOS Button, ASUS Stainless Steel Back I/O
I/O back plate
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Charger+, ASUS Update, ASUS AI Suite III
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
18.3 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good upgrade
Reviewed by Anonymous on 31/12/2014
All worked brilliantly. Overclocked to 4.2, 4.1, 4.0 and seems to be settled at 3.9, though it may have gone higher with some volt changes. Added a locally sourced Antec PSU as my existing PSU was due to be replaced anyway. Used my old Ice 7 Cooler for now (25-29C at idle and maybe 40 under load) but will fit a 212 EVO in soon.
I thought I'd post this just to let folk know it does still overclock and with this board. I'd already fitted a new Kingston SSD Drive, 2TB Seagate HDD, new monitor, new DVD Drive, OS Win 7 Pro 64 bit, Zalman Z3 case (love this case) and my existing GSX 550Ti Video Card for now. Going for a GSX 760 or 770 later.
The computer is soooo quiet I wondered if I'd wired it wrong or not switched on. Boots in 15-30 secs, shuts down before I can stand, installs Win 7 Pro in 12 minutes from an empty drive. Not bad for a low cost CPU, budget board and my Kingston SSD that speeds it all up. 8 gig of memory makes a big difference too.
Scroll to top
