BT.com
Wishlist
Asus Intel Gamer/Overclocking Bundle (Inc. Sabertooth P67, Intel Core i7-2600K & 8GB DDR3 Memory)
Delivery
Standard Due date unavailable
Dunc's Deal Alert
During November 2011 anyone who buys one of this Asus Intel Gamer/Overclocking Bundle will be able to claim a FREE THREE GAME BUNDLE! This includes download vouchers for Shogun: Total War 2, Dirt 3 and Medal Of Honor on PC. Simply order the item and then email duncsdeals@dabs.com with your Sales Order Number and Mailing address and the vouchers will be posted within 48 hours.
Exclusive Self-Build Special Bundle
High Performance - Without The High Price Tag!
Take the fear out of Self-Build with this tested Intel Gamer/Overclocking Bundle! We test it so you don't have to! Motherboard, CPU & Memory - Boxed & Ready To Rock!
Asus SABERTOOTH P67 REV 3.0 - New P67 B3 Revision
Intel P67 Based Military-grade Motherboard with Thermal Armor
This motherboard supports Intel second generation Core i7/Core i5/Core i3 processors in the LGA1155 package, with memory and PCI Express controllers integrated to support 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 2.0 lanes. This provides great graphics performance. Intel second generation Core i7/Core i5/Core i3 processors are among the most powerful and energy efficient CPUs in the world.
SABERTOOTH P67 brings multi-GPU configurations through both SLI and CrossFireX. This motherboard features the powerful Intel P67 platform, optimizing PCIe allocation in multiple GPU configurations. Expect a brand gaming style like you've never experienced before.
  • Intel® LGA1155 socket for Intel® 2nd Generation Core™ i7/ Core™ i5/ Core™ i3 Processors
  • Intel® P67 Express Chipset
  • TUF Thermal Armor - Total Airflow-Boosting Heat Dissipation
  • TUF Thermal Radar - Real Time Temp Detection and Heat Removal
  • TUF Components [Alloy Choke, Cap. & MOSFET; Certified by Military-standard] - Certified for Tough Duty
  • E.S.P. [Efficient Switching Power Design] - Optimal power efficiency for key components.
TUF Thermal Armor
Total Airflow-Boosting Heat Dissipation. The TUF Thermal Armor is the world’s first ever thermal design for the entire motherboard, not just for select critical areas. It safeguards the system against hot air generated by connected cards and components, keeping temps down. With its sophisticated and agile integrated shunt design, the Thermal Armor improves cool air circulation, directing it towards every important part for a complete motherboard cool down. It effectively conducts hot air away and out of the case through special airflow channels, contributing to enhanced system stability and extending component lifespan!
TUF Thermal Radar
Real Time Temp Detection and Heat Removal. The TUF Thermal Radar monitors temps in critical parts of the motherboard in real time, automatically adjusting fan speeds to make sure the system maintains high stability without overheating. It consists of multiple sensors for various components on the motherboard, giving users the ability to monitor each one individually. The Thermal Radar automatically calculates ideal fan speeds based on different parameters selected by users for each component, keeping everything cooler and longer lasting
DIGI+ VRM
Herald the Arrival of a New Digital Power Design Era. The new ASUS DIGI+ VRM design upgrades motherboard power delivery to a digital standard. The 8+2 digital architecture provides the highest power efficiency, generating less heat to enhance longer component lifespan and ensure minimal powerloss. With ASUS DIGI+ VRM, users can easily adjust power phase performance, enabling new PWM voltage and frequency modulation controls. Digital 8+2 power phase design also expands the modulation spectrum for improved stability and lower VRM switching noise by dynamically detecting system load, empowering users with superior flexibility and perfect precision to ensure optimized performance, extreme system stability, and greater power efficiency.
Intel Core i7-2600K 3.40GHz LGA1155 8MB Cache Processor (BX80623I72600K)
With faster, intelligent, multi-core technology that applies processing power where it's needed most, Intel Core i7 processors deliver an incredible breakthrough in PC performance. They are the best desktop processors on the planet.
You'll multitask applications faster and unleash incredible digital media creation. And you'll experience maximum performance for everything you do.
Patriot Memory 8GB (2 x 4GB) Viper Xtreme Series PC3-15000 1866MHz CL9 Division 2 Edition (PXD38G1866ELK)
Patriot's Viper Xtreme Series, Division 2 Edition memory kits are designed for Intel's® 2nd Generation Core™ processors. Engineered for PC Gamers and enthusiasts the Viper Xtreme Division 2's utilize a custom designed heatshield solution with an outer shield built around a copper core to provide enhanced cooling. Each module has 6 grams of copper at its core paired with extruded aircraft-grade aluminum outer shield. Built from only using the highest quality pre-sorted IC's available, they are rigorously tested and validated on the Intel® 6 Series platform to achieve maximum performance and stability. These modules are engineered to reach PC3-15000 (1866MHz) at 9-11-9-27 timings and are available 4GB kits (2 x 2GB) and 8GB kits (2 x 4GB). Each module is 100% hand-tested to quality assurance and is backed by a full-lifetime warranty and industry leading customer service.
ASUS SABERTOOTH P67 - 3.0 B3 - motherboard - ATX - LGA1155 Socket - P67
Motherboard - ATX
Chipset Type
Intel P67 Express
Processor Socket
1 x LGA1155 Socket
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600, 4 x SATA-300 (RAID), 1 x eSATA-300, 1 x powered eSATA-300
USB / FireWire Ports
2 x USB 3.0 + 1 x FireWire + 8 x USB 2.0 + ( 2 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel P67 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz
Speed
PC3-14400, PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC882
High Definition Audio
LAN
Network Controller
Intel 82579
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , JMicron JMB362: SATA-300 -connectors: 1 x 7pin eSATA, 1 x 11pin eSATAp - 2 devices
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 1 x FireWire - 6 pin FireWire , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 8 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
2 x USB 3.0 , 1 x FireWire
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, ASUS EFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, MemOK!, 8+2 Phase Power Design, ESD Guards, TUF Engine!, Q-DIMM, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, TUF Thermal Armor, TUF Thermal Radar, ASUS DIGI+ VRM, AMD Quad CrossFireX technology support
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS Live Update, ASUS AI Suite II
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
