BT.com
Wishlist
Asus H81-PLUS S1150 Intel H81 DDR3 ATX
Asus H81-PLUS S1150 Intel H81 DDR3...
£58.78
1 in stock
£58.78
Add to wishlist
Delivery
Standard 3-5 working days
H81 features new high-endurance 5X Protection and superfast USB 3.0 transfer speed
  • ASUS 5X Protection - All-round protection provides the best quality, reliability, and durability
  • USB 3.0 Boost (UASP Support) - 170% faster transfer speeds than traditional USB 3.0
  • New UEFI BIOS - Friendlier, easier, and more intuitive with helpful info added
  • Ai Suite 3 - One-stop access to innovative ASUS features
  • Network iControl - Real-time network bandwidth management
Intel® LGA1150 4th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors Ready
This motherboard supports Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors in the LGA1150 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (2 DIMM) DDR3 memory and 16 PCI Express lanes. This provides great graphics performance. Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world.
Intel® H81 Express Chipset
The Intel® H81 Express chipset is a single-chipset design that supports socket LGA1150 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It natively supports up to two USB 3.0 ports for up to ten times faster transfer rates than USB 2.0. Moreover, the Intel® H81 Express chipset also supports iGPU functionality, letting users enjoy the latest Intel integrated graphics performance.
ASUS H81-PLUS - motherboard - ATX - LGA1150 Socket - H81
Motherboard - ATX
Chipset Type
Intel H81 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600, 2 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 2 x USB 2.0 + (6 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel H81 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe x16 , 2 x PCIe 2.0 x1 , 3 x PCI
Storage Interfaces
SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x VGA , 2 x USB 3.0 , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack , 1 x serial , 1 x parallel
Internal Interfaces
6 x USB 2.0 - header , 1 x audio - header , 1 x SPDIF out - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, ASUS EFI BIOS, UEFI BIOS, SMBIOS 2.7 support
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, Intel Clear Video Technology, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Fanless Design Heatsink, ASUS USB 3.0 Boost technology, ASUS Network iControl, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Low EMI Solution, Disk Unlocker, ESD Protection, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, ASUS Boot Setting, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Charger, ASUS Update, ASUS AI Suite III
Plug and Play, ACPI 2.0a, ErP Ready
30.5 cm
18.8 cm
£58.78
Save on this ideal PC Build kit!
Save £10.63
£77.95
Scroll to top
