Asus H170-PRO/USB 3.1 Intel H170 S1151 DDR4 M.2 USB TypeC ATX
Standard 1-3 working days
This supreme motherboard comes with 5X Protection II for dependable stability, DDR4 support and lightning-fast USB 3.1. Advanced 5X Protection II employs high-quality components, excellent circuit design, and high standards to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build - the result of decades of engineering experience from the famous motherboard brand.
ASUS H170-PRO/USB 3.1 - motherboard - ATX - LGA1151 Socket - H170
Motherboard - ATX
Chipset Type
Intel H170 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
1 x USB-C + 2 x USB 3.1 + 2 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
HD Audio (8-channel)
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel H170 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
Supported RAM
Max Size
64 GB
Bus Clock
2133 MHz
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
1024 MB
Audio Codec
Realtek ALC887
High Definition Audio
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1 , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCI
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x DisplayPort , 2 x USB 2.0 , 2 x USB 3.1 , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x USB-C
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, AMD Quad CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Intel Small Business Advantage support, Low EMI Solution, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, LANGuard, USB 3.1 Boost, ASUS Overvoltage Protection, ASUS 5X Protection II
I/O back plate, 1 x M.2 screw
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Mobo Connect, PC Cleaner, Media Streamer, ASUS EZ Flash 3
Plug and Play
30.5 cm
22.4 cm
Scroll to top
