BT.com
Wishlist
Asus GeForce GTX 950 2GB GDDR5 PCIe3.0 Small Form Factor ITX
Delivery
Standard Due date unavailable
Small form factor PCs based on mini ITX motherboards are a popular choice for gamers and home users. Their compact cases are much easier to transport to LAN parties than a standard desktop PC, and stylish designs with comparatively low power requirements make them a natural choice for home theater PCs. The ASUS GeForce GTX 950 mini is designed to maximize the potential offered by mini ITX motherboards by delivering high performance graphics. It uses an innovative thermal design that combines a heat-spreading vapor chamber and the CoolTech fan, which uses wide-angle airflow and venting to cool critical graphics card components.
ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
Redesigned with an intuitive UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
ASUS GTX950-M-2GD5 - graphics card - GF GTX 950 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 950
2 GB GDDR5
Core Clock
1026 MHz
Boost Clock
1190 MHz
CUDA Cores
768
Effective Memory Clock
6.61 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
DVI-I , DisplayPort , HDMI
API Supported
OpenGL 4.5
4 cm x 17.2 cm x 11.2 cm
Microsoft Certification
Compatible with Windows 7
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1026 MHz
Boost Clock
1190 MHz
CUDA Cores
768
Max Resolution
4096 x 2160
API Supported
OpenGL 4.5
Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, CoolTech Fan, GPU Tweak Streaming, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.61 GHz
Bus Width
128-bit
Additional Requirements
6 pin PCI Express power connector
150 Watt
Software Included
Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster (14 days Premium licence)
4 cm
17.2 cm
11.2 cm
Limited warranty - 3 years
Accessories
£9.99
£7.28
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£39.09
£52.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.47
£17.48
Scroll to top
