BT.com
Wishlist
Asus GeForce GTX 760 1006MHz 2GB PCI Express 3.0 HDMI DirectCU II OC Mini
Delivery
Standard 3-5 working days
ASUS GeForce® GTX 760 DC Mini small form factor gaming graphics card
  • DirectCU Mini with vapor chamber offers 20%(7.5?) cooler and 3X quieter performance
  • New and advanced CoolTech Fan drives wider airflow to keep critical components cool
  • Direct Power ensures stable performance with 56% less impedance and a 17% cooler PCB
  • Super Alloy Power components increase product longevity by up to 2.5X compared to reference
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface
Small form factor PCs based on mini ITX motherboards are a popular choice for gamers and home users. Their compact cases are much easier to transport to LAN parties than a standard desktop PC, and stylish designs with comparatively low power requirements make them a natural choice for home theater PCs. The ASUS GeForce GTX 760 DirectCU Mini is designed to maximize the potential offered by mini ITX motherboards by delivering high performance graphics. It uses an innovative DirectCU thermal design that combines a heat-spreading vapor chamber and the CoolTech fan, which uses wide-angle airflow and venting to cool critical graphics card components.
Small Form Factor for ITX Builds
DirectCU Mini measures just 17cm in length-making it the perfect choice for compact gaming PCs.
DirectCU Mini
Superior cooling and acoustics are created with exclusive DirectCU thermal design and fan assembly. Award-winning DirectCU now includes custom vapor chamber technology and the new and advanced 360-degree CoolTech axial fan. Even in DirectCU Mini form, the proprietary design delivers up to 20% cooler temps and three times quieter performance than reference.
Direct Power
Small size but big in power. Proprietary DirectCU Mini features a custom PCB and VRM design featuring Direct Power technology. This provides high quality and reliable power delivery to the GPU, whether for gaming or overclocking. In addition, superior efficiency reduces PCB temperatures by 17%.
OC-selected 1072MHz core
1072 MHz Boost clock for better performance and outstanding gaming experience
GPU Tweak: Real-time intuitive graphics tuning
  • Shows detailed specs and actual card status with GPU-Z
  • Monitoring widget provides real-time detailed multi-parameter info
  • Automatically checks and updates drivers and BIOS versions
2GB GDDR5 Memory
On-board memory for the best gaming experience & the best resolution
Graphics GPU Features
  • NVIDIA GeForce: Powered by GeForce® GTX 760
  • NVIDIA® GPU Boost: Push the breathtaking performance of the GeForce GTX graphics cards to new levels with NVIDIA GPU Boost. This technology dynamically maximizes clock speeds to bring out the best performance in every game.
  • NVIDIA® Adaptive V-Sync: Get more than just faster frame rates. Get ultra-smooth gaming every time with NVIDIA gaming innovations - Adaptive Vertical Sync. This technology dynamically adjusts Vsync to current frame rates for maximum playability.
  • NVIDIA® PhysX® ready: Play games with advanced effects such as blazing explosions and lifelike characters with 10X faster switching between graphics and physics processing, enabling more complex effects to be rendered in real time.
  • NVIDIA SLI Ready: Multi-GPU technology for extreme performance. NVIDIA 3D Vision Ready
  • NVIDIA® 3D Vision™ Surround Ready: Transform hunreds of PC games into stereoscopic 3D and enjoy immersive full HD 3D gaming across three displays at an incredible 5760x1080 resolution.
  • PCI Express 3.0: Delivers double the bandwidth per lane of PCIe 2.0 for faster GPU-CPU communication. Full DirectX 11.1 API support
  • Microsoft DirectX 11.1 API (feature level 11_0): Brings new levels of visual realism to gaming on the PC and get top-notch performance.
  • Microsoft Windows 8 compatible: Gives you access to advanced computing experiences with the latest operating system so you get more done with your
ASUS GTX760-DCMOC-2GD5 graphics card - GF GTX 760 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 760
2 GB - GDDR5
Core Clock
1006 MHz
Boost Clock
1072 MHz
CUDA Cores
1152
Effective Memory Clock
6.008 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
DVI-I (dual link) ¦ DVI-D (dual link) ¦ HDMI ¦ DisplayPort
API Supported
DirectX 11.1
4.06 cm x 17.01 cm x 12.19 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1006 MHz
Boost Clock
1072 MHz
CUDA Cores
1152
Max Resolution
2560 x 1600
API Supported
DirectX 11.1
Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Super Alloy Power technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, CoolTech Fan, ASUS DirectCU Mini Technology, Direct Power technology , HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
4.06 cm
17.01 cm
12.19 cm
Scroll to top
