BT.com
Wishlist
Asus GeForce GTX 750 Ti 2GB GDDR5 PCI-E 3.0 HDMI DirectCU II
Delivery
Standard Due date unavailable
All-new graphics card with exclusive DirectCU II and 0dB fan technologies boosts game speed by up to 7.7%, and stays 58% cooler and 3X quieter than reference
Strix GTX 750 Ti OC, a new graphics cards powered by the NVIDIA® GeForce® GTX™ 750 Ti graphics-processing unit (GPU) and designed for players who like to game on the edge of instinct.
Taken from the ancient Roman and Greek word for owl, Strix is the brand name for the stunning new ASUS gaming-gear series. Strix means the keenest hearing and sharpest eyesight and the ability to feel the environment, enabling the player to detect and react to even the slightest movement. Strix means survival on the very edge of instinct. Strix is in gamers' blood, just as it is in ours.
Strix GTX 750 Ti OC is packed with exclusive ASUS technologies, including DirectCU II for cooler, quieter and faster performance for incredible action gaming, and 0dB-cooling technology for light gameplay in total silence and Blu-ray movie playback that's free from distracting background noise.
The new card also features exclusive ASUS Super Alloy Power components for enhanced durability and cooling, and GPU Tweak for overclocking and online streaming that's as simple as it is flexible.
Strix GTX 750 Ti OC is fitted with 2GB of high-speed GDDR5 video memory and races along at boosted speeds of up to 1202MHz.
Play in total silence, and 7.7% faster and 58% cooler than reference
Strix GTX 750 Ti OC is equipped with exclusive DirectCU II cooling technology. This innovative design puts highly-conductive 6mm copper cooling pipes in direct contact with a card's GPU, so heat is dissipated quickly and with extreme efficiency. The new card also benefits from a heat-sink that delivers a heat-dissipation area that's 190% larger than reference, allowing Strix GTX 750 Ti OC to perform 58% cooler and run three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise.
When playing at high-definition (HD) resolutions of up to 1920 x 1080 pixels, and in environmental temperatures of up to 50°C, the Strix GTX 750 Ti OC automatically stop its fan -- allowing gamers to enjoy titles like Counter-Strike Online in absolute (0dB) silence.
Built for durability, designed to perform
Strix GTX 750 Ti OC is built with Super Alloy Power components for enhanced durability and cooling. Solid-state capacitors, concrete-core chokes and hardened MOSFETs are all designed to withstand much greater stress thanks to the application of specially-formulated materials. Super Alloy Power technology also reduces power noise such as buzzing and increases a graphics card's longevity by up to two-and-a-half times (2.5X) greater than reference.
Strix GTX 750 Ti OC also includes GPU Tweak, an ASUS-exclusive tool that enables users to control GPU speeds, voltages and video-memory clock speeds in real time -- so overclocking is both easy and can be carried out with high confidence.
GPU Tweak's built-in streaming tool lets users share on-screen action over the internet in real time, meaning others can watch live as games are played. It's even possible to add a title to the streaming window along with scrolling text, pictures and webcam images.
  • NVIDIA GeForce® GTX™ 750 Ti
  • PCI Express® 3.0
  • 2048MB (2GB) GDDR5 memory
  • 1124MHz base clock speed
  • 1202MHz boosted speed
  • 5400MHz memory clock
  • 128-bit memory interface
  • 1 x Dual-link DVI-I output
  • 1 x DisplayPort output
  • 1 x HDMI output
ASUS STRIX-GTX750TI-OC-2GD5 - graphics card - GF GTX 750 Ti - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750 Ti
2 GB GDDR5
Core Clock
1124 MHz
Boost Clock
1202 MHz
CUDA Cores
640
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
DVI-I (dual link) , DisplayPort , HDMI
3.81 cm x 19.6 cm x 12.2 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1124 MHz
Boost Clock
1202 MHz
CUDA Cores
640
Dual Fan Design, Super Alloy Power technology, ASUS DIGI+ VRM, NVIDIA G-Sync ready, GPU Tweak Streaming, ASUS DirectCU II with 0dB Fan Technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
75 Watt
Software Included
Drivers & Utilities, ASUS GPU Tweak
3.81 cm
19.6 cm
12.2 cm
Accessories
£9.99
£7.28
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£39.09
£52.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.47
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Worth the extra if you like it quiet
Reviewed by Anonymous on 26/12/2015
The 750ti is the most powerful graphics card you can currently buy that can take all of the power it requires from the PCI slot - A bonus for those with older power supplies or a less powerful supply.
The Asus Strix cooler is very well thought out with two small very quiet fans only spin up when the GPU reaches 50ºC. This results in total silence when doing mundane tasks such as browsing or playing back media files.
Even under intense loading, I could not hear it over the minimal noise from the hard drive.
A nice set of outputs is a bonus, this card has HDMI, DVI and Displayport which is really the full set.
Working nicely coupled with a i3 4160 in a machine with a small 350watt power supply.
There are cheaper options which are marginally noisier or with more limited display options which might be worth considering.
Overall, extremely pleased. I did think the plastic shrouding a little flimsy and the fans look like toys, but once it is in the case this is unimportant.
Scroll to top
