BT.com
Wishlist
Asus GeForce GTX 1070 DUAL 8GB GDDR5 PCIe3.0 Graphics Card
Delivery
Standard Due date unavailable
DUAL-GTX1070-8G
ASUS Dual GeForce® GTX 1070 graphics provide sweet spot performance
Patented Wing-Blade Fans for max air flow with 105% more air pressure.
Perfectly matched with ASUS X99-A II Overview motherboards for optimised style and performance.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
VR-friendly HDMI Ports for immersive virtual reality experiences.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
Double the Performance
ASUS Dual GeForce® GTX 1070 comes equipped with Patented Wing-Blade Fans for max air flow with 105% more air pressure. While exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming. ASUS Dual GeForce® GTX 1070 is perfectly matched with your ASUS X99-A II motherboard!
Optimised Style and Performance
Perfectly matched with ASUS X99-A II motherboards
ASUS Dual GeForce® GTX 1070 graphics card and X99-A II motherboards share perfectly matching color themes and are ready for Windows 10. Dual GeForce® GTX 1070 is equipped with DirectX 12 to squeeze more graphics performance from the CPU and prevent GPU bottlenecks.
VR-Friendly HDMI Ports
Enjoy immersive virtual reality experience
ASUS Dual GeForce® GTX 1070 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
ASUS DUAL-GTX1070-8G - graphics card - GF GTX 1070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1070
8 GB GDDR5
Core Clock
1531 MHz
Boost Clock
1721 MHz
CUDA Cores
1920
Effective Memory Clock
8.008 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort
API Supported
DirectX 12, OpenGL 4.5
4.3 cm x 24.2 cm x 13 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1531 MHz
Boost Clock
1721 MHz
CUDA Cores
1920
Max Resolution
7680 x 4320
API Supported
Nvidia SLI Multi-GPU Technology, Native HDMI, Nvidia SLI ready, NVIDIA G-Sync ready, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, Wing-Blade Fans, HDCP
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
256-bit
Software Included
Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
4.3 cm
24.2 cm
13 cm
Scroll to top
