BT.com
Wishlist
Asus GeForce GT 730 2GB PCI-E 2.0 HDMI Silent with LP Brackets
Delivery
Standard Due date unavailable
ASUS GT 730 silent and low profile graphics card with DirectX®11 and HDMI support
  • Silent passive cooling means true 0dB - perfect for quiet home theater PCs and multimedia centers.
  • Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
  • GPU Tweak Streaming share on-screen action in real time - so others can watch live as games are played.
  • Graphics Engine: NVIDIA GeForce GT 730
  • Bus Standard: PCI Express 2.0
  • Video Memory: GDDR3 2GB
  • Engine Clock: 902 MHz
  • CUDA Core: 384
  • Memory Clock: 900 MHz ( 1800 MHz GDDR3 )
  • Memory Interface: 64-bit
  • Resolution: DVI Max Resolution : 2560x1600
  • Interface: D-Sub Output : Yes x 1 , DVI Output : Yes x 1 (DVI-D), HDMI Output : Yes x 1 , HDCP Support : Yes
  • Software: ASUS GPU Tweak & Driver
  • Dimensions: 5.4 " x 2.71 " x 1.18 " Inch / 13.7 x 6.9 x3 Centimeter
ASUS GT730-SL-2GD3-BRK - graphics card - GF GT 730 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0
Graphics Engine
2 GB DDR3
Core Clock
902 MHz
CUDA Cores
384
Effective Memory Clock
1.8 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
DVI-D , VGA , HDMI
API Supported
DirectX 11
Fanless
3 cm x 13.7 cm x 6.9 cm
Microsoft Certification
Compatible with Windows 7
Graphics card - low profile - fanless
Bus Type
PCI Express 2.0
Graphics Engine
Core Clock
902 MHz
CUDA Cores
384
Max Resolution
2560 x 1600
DVI-D , VGA , HDMI
API Supported
DirectX 11
Native HDMI, ASUS 0-dB thermal solution, Nvidia PhysX-Ready, Super Alloy Power technology, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
64-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
3 cm
13.7 cm
6.9 cm
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
