BT.com
Wishlist
Asus GeForce GT 730 1GB PCI-Express 2.0 HDMI Silent
Delivery
Standard Due date unavailable
The ASUS GT 730 is the fantastic new graphics card from ASUS. Engineered with a highly-efficient 0 dB thermal design, it dissipates heat in complete silence - making GT 730 the perfect choice for your slimline home-theater PC (HTPC) build. Advanced EMI shielding reduces electromagnetic interference by up to 66% for a stable signal, pin-sharp images and safer and healthier computing.
ASUS GT730-SL-1GD3-BRK - graphics card - GF GT 730 - 1 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 730
1 GB GDDR3
Core Clock
902 MHz
CUDA Cores
384
Effective Memory Clock
1.8 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
DVI-D , VGA , HDMI
API Supported
DirectX 11
Fanless
3 cm x 13.7 cm x 6.9 cm
Microsoft Certification
Compatible with Windows 7
Graphics card - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
902 MHz
CUDA Cores
384
Max Resolution
2560 x 1600
DVI-D , VGA , HDMI
API Supported
DirectX 11
Nvidia PhysX-Ready, Super Alloy Power technology, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, HDCP
Size
1 GB
GDDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
64-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
3 cm
13.7 cm
6.9 cm
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
